Hard to say, I think most of the better chips are from early batches but it is like a lotto TBH. GL
update still on 1053 @ 5.1,waiting for 13XX
http://img703.imageshack.us/img703/9883/51xv.th.jpg
Uploaded with ImageShack.us
http://img84.imageshack.us/img84/3374/51xpi.th.jpg
http://img715.imageshack.us/img715/2955/51xlinx.th.jpg
Voltage-1.49
ram-4GB G.Skill DDR3-1866 8-9-8-24-1T
cooling-water
Batch number#L040B671
You were thinking of posting, and then deciding that it is a good idea to post in 1920x1080.... In a forum? Mind me asking; Do you see the problem?
My new toy!
http://www.abload.de/img/_5000_1344bayv.jpg
L040B307 #2476
Dislike :p:
It's funny my chip benches 5775Mhz but for a LinX run @ 5G I need 1.38v + LL2 = 1.41v. You would think these chips running at 1.35v for prime would be able to have a higher top end? I suppose it comes down to what multis work, 55, 56, or 57, hard to say.
Yeah, that's usually the case. Good chips would do good in low-volt action too usually. I've been running with this for 24/7 lately. Haven't push the chip over 1.3v yet tho.
4.2GHz(42x100) 1.17v 30-min Prime small FFT :)
http://img.techpowerup.org/110130/Capture025.jpg
I have been thinking what is holding back with these SB cpu's.. I have chip wich can do 54x 100bclk just fine but i cant get 55x work at all in windows. Then i try to put 103bclk and then my max multiplier is only 53-54x. At 106bclk it will work only with 51x multi. So could it be more MHz limited thing or is this all because of mine Asus P8P67 vanilla mb? I will get gigabyte board tomorrow to see if it helps a bit or not. I have tryed all voltages without any help. Only good thing is that this chip wont need too much vcore :)
Just curious if som1 have lilbit more experiment about this thing with many many chips tested!
I went thuogh all pages i may have missed it but anyone see 044A892 before?
Thats a newer batch. So no.
Yeah there is a L045A912 on the bay but couldn't find any info on that either...
I7 2600K: Batch L042B208 1.52v @ 5127 MHz All four cores w/ HT on
8GB Ripjaw-X 2133
Water w/EK Supreme HF
Asus P67 Deluxe
Temps still low IMHO
http://img16.imageshack.us/img16/6332/5127b.jpg
I got a L041B702 batch, anyone got info on it?
Ugh Daddyjaxx you could get a seizure just continuously staring at your avatar!
Intel Core i5 2500K
Noctua NH-U12P SE2
Asus P8P67 (BIOS 1204)
Exceleram Red Culvert DDR3-1600 6-8-7-24 2 x 2GB
Quick and dirty 5.1GHz :D
Sorry for forgetting to capture the batch # :(
http://img.techpowerup.org/110201/07.jpg
I also have that batch with the same OCing capability, not as good as what I have seen of other users' (of different batch) though. I originally bought an L040B305 that OCs up to 5Ghz as well. I thought I would try the B208 just for the heck of it. There was another batch L042B243, which I didn't pick. Now that I know how the B208 OCs, I wonder how the B243 can OC, if it can do it better (or worse) than my two.
The batch # is on your CPU Box. Just type it for us to see.
first test looks good batch l042b074 :yepp:
http://img31.imageshack.us/img31/9757/33367459.jpg
GiN - silly question but is HT off?
:up:
