7-7-6 20 on mem next step?
Just ran 1M found the max bclk at 58x on my 2500K...
Next up tweaking 32M :up:
Last week I tested ten 2600K L044B693. They all were bad. One of them could boot 2c/2t 5600 under water, but had no stability. Under SS it worked at 55xxMHz only, 5600 was unreachable
Seems in ex-USSR(Ukraine, Russia) have no good 2500/2600K. :down:
Tested 16 pcs. of 3101A201s...pretty decent batch averaging 53Xs with SS
Even with small samples I ended up with (1) 5.50Ghz s/n A1181 - (1) 5.65Ghz s/n A1499 - (1) 5.75Ghz s/n A1983 4C/8T
The only similiarity I can think of those >55X cpus are s/n 1000ish and between 80~99 for the last two digits
Code:
........ Hyper ....... PSC
........ 2x2GB ....... 4x2GB
........ 50x ......... 47x
........ 100.0 ....... 106.4
........ 5001.x ...... 5001.x
........ 1067mhz ..... 1135mhz
........ 7-7-5-20 .... 8-10-7-26
RTL .... 33|34 ....... 36|37
tRFC ... 55 .......... 74
tWR .... 6 ........... 8
CR ..... 1 ........... 1
tRRD ... 4 ........... 4
tWTR ... 4 ........... 4
tRTP ... 4 ........... 4
tFAW ... 16 .......... 16
tWL .... 6 ........... 6
32M .... 6m31.812 .... 6m31.797
2x2GB GTX2
100.0 x50 (100.2 bios set)
http://i447.photobucket.com/albums/q...E_GTX2_4GB.png
4x2GB Exceleram Speedslider
106.4 x47 (106.6 bios set)
http://i447.photobucket.com/albums/q...7E_EXE_8GB.png
pifection mr cheapseats!
ganged?
interleaved?
yes sir, both with rank interleave enabled.
what do you mean by ganged though ?
woops amd terminology ...
rank and channel interleaved ..thats what i meant :D
thanks
http://i48.photobucket.com/albums/f2...976/600672.jpg
need more efficiency!!! :confused:
Awesome job Nick, as always of course :) :up: So 2x2GB GTX2 performs similarly to 4x2GB PSC right?
http://i48.photobucket.com/albums/f2...976/633250.jpg
obligitory 5ghz shot. im missing something somewhere. olive gave me .2
nice work mr b.
will u be trying 4 sticks?
Cheapseats thanks for sharing :) .....Always interesting in reading your posts,lots of quality informations within...
With proper PSC,6-10-7 would be doable and that would buy some effieciency :)
5ghz
i cant catch zeneffect lol
It's all about memory now Honda. For example, tighten that tRP from 7 to 6 and you'll get about half a second :) Work on your RAMs more :up:
oh..thanks for advice..i'll keep at it... the gskills that i got aren't friendly with tCL(7) ....so sad :(
sorry that run was kinda not tweaked ...
edit:
finalrun attached..gskills sucks with tCL(7)
can't quite catch the hypers ...
Haha yeah Aristidis's run is damn fast, he's a good SuperPi 32M bencher :D ;)
But your runs are great as well guys. I'll soon join you with some PSC and a 2500K @ 5GHz. 6m33sec is my goal :)
