Hi computurd.my cache memory seems 800 mhz.Or am I wrong?I think tekram wrote wrong information.I hope it is...
2GB and 4GB modules have been readily available for a while now at the $99 and $250 pricepoints.
2GB: http://www.pc-pitstop.com/sas_contro...ARC62402GB.asp
4GB: http://www.pc-pitstop.com/sas_contro...ARCRMD24G8.asp
this is the 1880 memory from Tekram. (800mhz)
http://tekram.com/store/product_info...roducts_id=161
That previously pictured part sure looks like DDR2-800 to me. :)
yeah, looks 800 to me too :) weird they had it listed at 533 on their site....
A small Hitachi Deskstar 7K3000 3TB 64MB, 7200rpm, 6Gb/S test @ my Areca 1880ix-24
They only had 4x 7K3000 3TB in stock :(
http://www.diskusjon.no/index.php?sh...ost&p=16788007
Having just spoken to an Areca tech, I plan on ordering an ARC-1880i controller to replace my LSI 9260-8i that is going back today.
Areca tells me that there are not any compatibility issues with the eVGA motherboards.
I was wondering if any of you ARC-1880 owners could comment on issues with the classified 3 (e770) motherboard.
thanks
bear in mind the 1880 without the chance to upgrade the cache is not going to perform nearly as well as the 9260. especially if you take fastpath into consideration. however, if you cant get the lsi to work at all then it really wouldnt matter, but i would highly recommend a 1880-12 -16 or -24. it seems these cards shine with the cache.Quote:
awesome! You are now my new best friend ;)
What I really want to do is put my 4 Vertex 2's on the ARC-1880i in RAID0 to use a Win7 boot drive and use the other 4 ports for individual 2tb drives (no RAID) JBOD. What ever drives are left over would go on the ICH10 ports.
My LSI 9260-8i left this afternoon for a better home at NewEgg and a refund. I should be ordering the replacement Areca by the middle of next week unless I read of some reason why another card would do a better job for me.
I wonder if Areca will offer the new wide coverage heatsink for 1880 owners! The CPU gets quite warm in a case with good airflow.
http://www.areca.com.tw/support/photo/ARC-1880ix-24.jpg
All the new batches have the new heatsink :)
^ still needs a fan which gets it ugly n dusty.. better watercooled
http://i52.tinypic.com/34ih1eu.jpg
http://i53.tinypic.com/qq1ki8.jpg
chc125 + mvr40+107.5mm plates
http://www.koolance.com/water-coolin...product_id=663
http://www.koolance.com/water-coolin...product_id=660
http://www.koolance.com/water-coolin...product_id=659
how bout this? single slot solution :D
http://i517.photobucket.com/albums/u...0-17-25370.jpg
http://i517.photobucket.com/albums/u...0-17-47347.jpg
http://i517.photobucket.com/albums/u...1/DSCF4614.jpg
http://i517.photobucket.com/albums/u...1/DSCF4607.jpg
http://i517.photobucket.com/albums/u...3-09-14380.jpg
oh and the obligatory temps before and after.
NOTE: BEFORE temps are at IDLE.
after temps are under PCMV load :)
(controller temp btw is the expander, that is with a copper HS installed on it that is actually smaller than the previous HS)
BEFORE
http://i517.photobucket.com/albums/u...1/ROCtemps.png
AFTER
http://i517.photobucket.com/albums/u...e1/roflMAO.png
That fourth picture looks like a mad-scientist lab! :up:
I have my controller on the bottom slot with a 120mm fan running at 1,000RPM under the controller.
http://www.dadepc.com/hmon.jpg
One other thing. I'm running an 1880-12 on a 760 classified that has USB issues so I purchased a pci-e usb 2.0 addon card. The strangest thing happened. The computer wouldn't power up with the card installed. I took it back to CompUSA and got a replacement thinking the first one was defective but the same thing happened with the replacement. I plugged the second card into a system I'm building for someone else on an Asus P6X58D and no problems. Then I installed the 1880 in the asus and once again the system wouldn't power up. It seems like a conflict with the 1880 which makes no sense to me at all. Anybody seen anything like this?
I ordered a NZXT IU01 Internal USB Expansion Device in the meanwhile. http://www.nzxt.com/new/products/cas..._usb_expansion
it is :) loop testing too so lots of wires about...got three pumps to run with that PSU stretching acrossQuote:
yeah the 'pile o gear' changes so much, no sense in making it purty :)Quote:
pretty typical PCMARK OCers setup
Even stock temps are acceptable - the new CPU can run up to 90C before there is alarm. I've seen it in the middle 60s but my case has strong flow.
WC'ing the raid card? Nuts! :eek:
The new heatsink is nice because with the front to back (or bottom to top for FT-02 users) works even better. If you wanted to WC the 1880ix cards you need a block to cover both the CPU and SAS controller - similar to a MB water block. (but do-able). Bringing the fittings off the card (aka single slot solution) is definitely a good idea with a crowded case. :)
you should insist that they mail you one for free. you are a customer and they obviously came up with the HS to alleviate heat issues, so i think they should send us one.
I just got off the phone with Tekram to find out that modifications have been made to the board (only the 1880-24) to accommodate the full coverage heatsink and it wont fit on the original version. They are offering a heatsink/fan combo similar to the one on the 1680 that is available for $10. I'm going to call Areca support to see if they will send me one at no charge.
excellent bit of news there tutto. also, if they in fact will not send it free, could you give us a link to where we could buy it? i looked at their site and dont see it!
