New Sponsor: Performance-PCs
Originally Posted by
Lu(ky
Looking good there Xion X2... Nice touch on the mobo polishing.. And I myself just bought the 280 rad grill from MCPCTech they are made solid..
Thanks, Lu(ky! MNPCTech makes awesome grills. :up:
CptDreadFlint
Very awesome grills, Xion X2! And yes, Bill is a pleasure to do business with! Great job and keep it up :up:
Thanks, Flint! Still enjoying your monstah project. :up:
aka_GK
wow, I wanna see how it will look finally
good job!
Thanks, GK!
Vinas
These kinds of projects do take forever... Meanwhile, I'm getting ready for another build already. Gulftown, new video cards, and the new SSD's are right around the corner. :up:
Keep up the good work on this build, even if it lasts until 2011. :p: Once complete then you can upgrade ;)
PS: Painting the caps is a better idea than grinding IMHO. Those caps are metal, but more delicate in a way that I'd want to mess with.
Thanks, Vinas! I've decided to first try using some sort of paint remover on the tops of the caps before sanding them. Anyone have any suggestions for a good paint remover that'd be safe to use on caps?
And now I'd like to announce another big sponsor who's come on board to partner with me on refleXion. :)
http://img38.imageshack.us/img38/6363/newlogos.jpg
PPCs will be sponsoring me with three of their nickel-plated RAM waterblocks, the RAM-33:
http://img36.imageshack.us/img36/6569/ram3301.jpg
http://img39.imageshack.us/img39/4351/ram3302.jpg
The staggered inlet/outlet design of these allow you to stack as many of them together as you like:
http://img3.imageshack.us/img3/7375/ram3303.jpg
Each one has a carved path for the coolant to travel so that it comes in contact with every memory chip.
http://www.performance-pcs.com/catal...ducts_id=25760
Given the mirror-like finish of these, they should go great in refleXion and help keep my three DDR-3 sticks nice and cool. Aside from that, they just look great and fit the theme well.
Thanks to Performance-PCs for their support in helping mold refleXion into its final form!
