please post your bios settings
Awesome awesome awesome. Well done, EVGA. Bootup bclk was one thing many guys were critizising. :up:
My BIOS setup for 24/7 OC on W3570 - 5025 MHz - Inbuilt singel stager
Dummy OC (Disabled)
Extreme Cooling (Mode 1)
Frequency Control
CPU Clock Ratio (25X)
CPU Host Frequency (Mhz) ( 201 )
Target CPU Frequency 5033 MHz
Target Memory Frequency 2013
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 4026 { 20X } )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 102 )
OC Recovery ( Disabled )
Memory Feature
Memory SPD ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 1333 MHz / 2:10 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 7 )
tRCD Setting ( 8 )
tRP Setting ( 7 )
tRAS Setting ( 20 )
tRFC Setting ( 74 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.4750 )
CPU VTT Voltage ( +225 )
CPU PLL VCore ( Auto )
**IOH PLL VCore (auto)
QPI PLL VCore (1.150)
DIMM Voltage ( 1.65 )
DIMM DQ Vref (+0mV)
IOH VCore ( 1.150 )
IOH/ICH I/O Voltage (auto)
ICH VCore (auto)
**VTT PWM Frequency ( 250 KHZ )
**CPU PWM Frequency ( 940 KHZ )
**CPU Impedance ( Auto)
**QPI Signal Compensation ( Auto)
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
*****Logical Processor Setting*****
Intel HT Technology (Enabled)
Active Processor Cores (All)
*****QPI Controller Setting*****
QPI Control Settings (Enabled)
QPI Link Fast Mode (Enabled)
QPI Frequency Selection ( 4.800 GT/s )
PCIe 115MHz and more VTT is the key, but 235 with low multi and 2 cores disabled, cause the CPU cant go higher on water. Also 21x230 2 cores enabled is not a problem, I tried a quick 1M test.
http://store.picbg.net/pubpic/C4/6B/...58d8ffc46b.JPG
Yes its awesome, now the mobo is really the best one :).
http://forum.nexthardware.com/galler..._screen001.jpg
http://forum.nexthardware.com/galler..._screen004.jpg
New Bios is rock
235 bclk easy
Code:Frequency Control
CPU Clock Ratio (20X + turbo on)
CPU Host Frequency (Mhz) ( 233 )direct boot
Target CPU Frequency 4183 MHz
Target Memory Frequency 1860
MCH Strap ( 1333 )
CPU Uncore Frequency (Mhz) ( 2 X memory )
PCIE Frequency (Mhz) ( 101 )
Memory Feature
Memory Frequency ( 1333 MHz / 2:8 )
Channel Interleave Setting ( 4 Way )
tCL Setting ( 7 )
tRCD Setting ( 7 )
tRP Setting ( 6 )
tRAS Setting ( 20 )
tRFC Setting ( 60 )
tRRD Setting (4)
RTL'S Settings (53/55/57)
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( 1.34 )
CPU VTT Voltage ( +175 )
CPU PLL VCore ( 1.80 )
IOH PLL VCore (1.25)
DIMM DQ Vref (-10mV)
IOH VCore ( 1.20 )
ICH VCore (auto)
CPU Feature
CxE Function ( Enabled )
230x21 ht off 1.52vcore all ok at boot up.....s224.bin is excellent :)
e759 mobo :)
just chiming in
I'm wrapping up a HAF932 build with a D0 stepping i7-920, Corsair HX1000 power supply, Mushkin DDR3 1600 RAM, WD 300GB VelociRaptor drives, etc.
I held off on the mobo until the last minute because I'm on the proverbial fence between the ASUS Rampage II Extreme X58 and the EVGA 3X SLI Classified.
I will be using a Prolimatech Mega Shadow CPU cooler, so that alone may make the Rampage II the board of choice for me since I have seen reports the similar Megahelems is a very tight fit at best on the Classified.
I don't currently do competitive overclocking, but am a hard core gamer / Flight Simulator X guy and will want to run my D0 at a stout overclock. I will eventually be running either twin ATI 5870 or EVGA GT380 GPU's in SLI. Need to see how the next several months play out on the video front.
All of my prior builds have used ASUS mobos, so I know how to flash the BIOS for the Rampage II every which way but loose.
Pardon the "noob to EVGA mobo" question, but what's the best = most convenient way to flash the BIOS on the Classified? Looks like the latest BIOS for the Classified is a pure winner and upgrading to it is not optional.
Thanks, gang! :up:
this is how i did it earlier today http://www.evga.com/forums/tm.asp?m=671353
just have your ups up and running....
I also love the new bootup bclk with this new bios. 235+ no problems :up:
Just ordered a classified myself, hoping for some Gulftown BCLK lovin :D
Can't wait to see the max stable BCLK on this beautyful motherboard.
@jcool
where did you order the CF?
Wave... they are hopefully gonna get a few in today or tomorrow. That's what my sales rep said anyway...
wave... not for me :(
I can PM you when I get a definite info on available boards.
yes. please :)
many thanks :D
The first page has been updated with links to the new bios for the 759 and 760
or
here is easyer operation to flash the bios
download tools :
Windows 98 BootFile
HP USB Disk Storage Format Tool v2.1.8.exe
How to create a bootable USB Drive
http://translate.google.com/translat...cheda%2F11.htm
Copy and paste to USB root
AWDFLASH.EXE
E760S61A.bin (or any .bin bios)
Go.bat
boot with your usb and just write :
go.bat
you can use go.bat for any bios flashing just edit .bat and change Bios name you want to flash
http://forum.nexthardware.com/galler...2009_13.43.png
PS :
you can use it for all bios flashing videos other boards ....
example : for Ati4890
change command line to
atiflash -f -p 0 4890.bin
save as go.bat
copy and paste 4890.bin + atiflash.exe in your bootable usb drive
and flash your card
hi guys, i changed from DFI T3eH8 to E760 :up:
started with s618, now on s61A :up:
s61A (17 sept)
231x19 boot 231bclk
QPI compensation Less (>222bclk or POST is slow)
QPI vcore 1.10V
IOH vcore 1.10V
pcie 105
clock skew 100ps (>225bclk or POST is slow)
http://i447.photobucket.com/albums/q...2M_8m06844.gif
s630 (14 sept)
232x19 boot 220bclk (max for boot)
QPI vcore 1.35V min
IOH vcore 1.40V min
pcie 105
clock skew 0ps
http://i447.photobucket.com/albums/q...2M_7m57250.gif
boot @ 240bclk x 21 windows xp :)
all good with the new bios :)
The E760 will work with a C0 stepping 920 right?
