same as mine, 4.5Ghz @ 1.45V, and runs cool around 70C, batch 3850A796 .. need to try 4.6Ghz, but Im waiting for my mobo to be replaced from RMA
Man I wish mine ran that cool at 1.45v. That is what mine is at 1.35v prime95. I have an excellent overclocker but on the flip side runs a little hotter than the norm.
This classified board is finicky and I am not used to it yet, I came from a Gigabyte. I am slowly get a little better with it...:up:
http://www.myalbumbank.com/albums/us...nature_img.jpg
I hope mine gets here Friday sometime so I can test it on my newly acquired MSI Eclipse Plus (with the NF200 chipset). Aso just bought a new case (Cooler Master HAF 932). This case is big and wide. It's gonna be fun! Thinking of taking a few pictures if anyone's interested...
I saw today a 3902axxx batch out at the store. I was so close on grabbing it anyone tried a CPU from 09 yet?
I tried 3851Axxx and it was worse than 3850A795 which is a really nice CPU.
For comparison, whatever the 3850 did, the 3851 needed 0.1V more to do.
So maybe the batches are starting to degrade again, or its just that the first batches were 975 binned that were re-labeled to 920 due to lack of production unit and the new batches are lowered binned cpus.
Time will tell I guess.
Anyway, I Just got a D0 3850A795 and Bloodrage GTI, together with Kingston T1 (Elpidia Hyper chips), they make some very nice results.
http://img29.imageshack.us/img29/1420/32m7m52s.jpg
The Bloodrage is a very nice board, too bad it stopped at the famous 222 "wall".
Damn thats very nice OC, what sort of temp you getting ?
Didn't really looked at the temps much, I need to make a serious run with LinX and see.
With my current WC setup I should probably be going at around 75c-80c degrees.
My D0 CPU arrived and I just finished hooking everything up except the HD/CD Drives. I dialed it instantly to 200 bclk and it POSTs just fine. The IOH Temp is Super Hot! It got all the way to 85c and still climbing up! Man oh man...I need a fan to cool it down. What's the highest IOH temp before I start to worry about it? I took some pictures and will post them here as soon as I find my adapter so I can upload the pictures to Photobucket.
I'm seeing 90/87/89/81 in LinX, and 80~83c in Prime, ambient is also around 26~27C, HOT HOT HOT! :flame:
http://bcphoto.org/misc/4.5ht.jpg
I think 4.51Ghz with HT enable is getting close to the limit of this chip for 24/7 with water. :yepp:
Check the voltage for the IOH.
Should be 1.1v/1.5v(stock).
i7 920 [3851A375] Short Test
Intel Core i7 920 Nehalem [3851A375]
DFI Lanparty UT X58-T3eH8
CORSAIR DOMINATOR 12800 2x6G
GeForce 7300GS
CORSAIR CMPSU-1000HX 1000W
WATER
http://cfile22.uf.tistory.com/image/...4A0A113A1E5444
http://cfile3.uf.tistory.com/image/1...4A0A113C1F13F7
http://cfile3.uf.tistory.com/image/1...4A0A113D207433
http://cfile23.uf.tistory.com/image/...4A0A113F211DD5
Finally getting a little better... EVGA Classified, water cooling with the heatkiller block...
http://img7.imageshack.us/img7/6077/229x19.jpg
http://img7.imageshack.us/img7/7355/4500intelburn.jpg
http://img7.imageshack.us/img7/1199/4657superpi.jpg
http://img7.imageshack.us/img7/3017/wprime5565.jpg
i7 920 [3851A375]
Water cooling the max clock test
4 cores 8 thread
GeForce 7300GS
WATER
http://cfile2.uf.tistory.com/image/1...4A0CC35A2D6326
http://cfile22.uf.tistory.com/image/...4A0CC35A2E31F8
http://cfile5.uf.tistory.com/image/1...4A0CC1C72CEC98
21x222
4669MHz 4 cores 8 thread
http://cfile2.uf.tistory.com/image/1...4A0CC1C82D960B
21x225
4727MHz 4 cores 8 thread
http://cfile2.uf.tistory.com/image/1...4A0CC1C92E2E02
21x228
4794MHz 4 cores 8 thread
http://cfile2.uf.tistory.com/image/1...4A0CC1C92F6BA3
21x229
4811MHz 4 cores 8 thread
namegt,
What mobo did you use for your 229x21 screen? Also, did you find that your max clock did or did not track well with Vcore? That is, many 920s, both C0 and D0 seem to reach their peak at relatively low voltage, so I'm wondering if you kept getting more CPU clock as you went to 1.45, 1.50, 1.55 etc.?
