http://premium1.uploadit.org/soundx98//ssAMD.gif
http://premium1.uploadit.org/soundx98//ssSIDEGLOW.gif
gallery http://www.uploadit.org/gallery/14200
Soundx98,
Nice clean & classy look. One of the best I've seen.
I like that kind of clean, sleek look. :up:
Good Job!
Jebus, a compliment from TheDude. Thank you very much man. I mean that very seriously.
If no one minds me elaborating a lil bit. I'm really happy with the Matrix Orbital and the LED Indicator Buss. They deliver a lot of information.
Silverstone TJ-067 Info here: http://www.silverstonetek.com/products-tj06.htm
*Removed front fan filter
*Replaced CoolerMaster fans with ThermalTake Smart Fans
*Rear fan holder rotated 90 degrees as it was necessary to mount Von Karajan module without hitting the fan.
*Added handles to the top. This is a steel case with Aluminum front panel.
*Sleeved and wire tied all visible wires. I hid the rest of them.
*Made Custom Flat Cable for Floppy Connection on Venus motherboard
*Changed DFI Stock chipset fan to Evercool VC-RE chipset fan TWICE (1st one D.O.A.)
Info here: http://www.bigbruin.com/html/evercool-vcre.htm
*Added 2x80mm Antec 80mm fans under HDD cage in brushed aluminum housing (I’m trying to keep One (1) Terabyte of storage cool)
*Ran all wires and connectors under the motherboard
*Spent hours on cable management (it was probably more like days)
*Vantec Silver Fan Buss in 5.25” Bay to control 80mm and 120mm front intakes, rear 120mm exhaust, and XP-90 heatsink fan. I chose this model cause it only changes the voltage from 7V to 12v. Means I don't have to worry about other hands on the knobs. All of the fans are Thermaltake A201X series smart fans with Blue LEDs –
Info here: http://www.thermaltakeusa.com/2005/...d/bluesmart.htm
(Note: I’ll be modding a Silverstone blank panel as the Vantec writing bugs me.)
*Matrix Orbital MX421 and customized LCDC software (Reprogrammed completely) Info here: http://www.matrixorbital.com and here www.lcdc.cc
*Dallas One-wire Thermal Probes (Accurate to within 0.5 degrees C)
pdf here: http://pdfserv.maxim-ic.com/en/ds/DS18S20.pdf
Examples of the Matrix Orbital’s display capabilities can be seen here:
http://www.uploadit.org/gallery/13039
*Custom STATUS LEDs on front panel – (They are multi-mode and work in conjunction with the MX421) How do they work? When rig is powered ON as follows:
LED1 Status
OFF/Connected to Internet
ON/Disconnected from Internet
FLASH/Chipset Fan not running
STROBE/CPU Fan not running
ON/STROBE/OFF (sequential) A voltage rail has dropped more than 1%)
LED 2 Status
OFF/CPU Temp below 35C
ON/Temp above 35C
FLASH/CPU Temp above 40C
STROBE/CPU Temp above 45C
ON/STROBE/OFF (sequential) Temp above 50C
LED 3 Status
OFF/GPU Temp below 45C
ON/GPU Temp above 45C
FLASH/GPU Temp above 50C
STROBE/GPU Temp above 55C
ON/STROBE/OFF (sequential) GPU Temp above 60C
These are High Output 5mm Blue LED in a chrome housing so they literally throw a laser like beam of light onto the wall across the room. Pretty hard to miss even sitting off axis.
*Dallas One-wire Thermal probes (one on Memory and one on Raptor with Chomerics T414 Thermal Tape) All information on the Matrix Orbital MX421is also displayed on the “Virtual Display” on one of the monitors.
*6.5” Farenheit LCD Internal display as second monitor
http://camerasandelectronics.com/it...tem=fart6502hrs
*15” Panasonic LCD EDTV for 3rd Monitor (Component In and TV).
Info here: http://www.lcdtvbuyingguide.com/pana...c-tc15lt1.html
Voltage and temps are all read by a custom MBM5 config for DFI boards.
http://www.dfi-street.com/forum/showthread.php?t=6798
Thanks again for the compliments
Awesome looking rig!Quote:
Originally Posted by scream
Soundx98,
I know what you mean about the info., I love my Matrix Orbital and my Digital Doc too.:D
There's another one that I forget the name of...some sort of analyzer that does everything but the dishes! :D
Brings out the gadget Geek in me!
BTW: Thanks for the software link :toast:
hehehe, sorry for being a little long winded. :slap:
But I'm sure the good Doctor (R.I.P.) and the Big Lebowski would approve :toast:
Nice job soundx98! :up:
can anyone tell me what LCD display is that?Quote:
Originally Posted by _CrAzY_BoY_
Originally Posted by DragonWoLf
I think it's this one, except in black.. http://www.frozencpu.com/lcd-46.html
Crazy Boy, what is that grill that you have to cover the radiator on top called?
The grid is an Aquacomputer for AIRPLEX 240. As i know Crazy Boy because i'm also portuguese and had watched is project at full detail, i can help too...
thank you!
it looks beautiful
Yes it is this... :clap:Quote:
Originally Posted by en4cer
That's Right, thanks Black Phoenix :toast:Quote:
Originally Posted by Black Phoenix
leter with Zalman 7000AlCu
http://strony.aster.pl/crollek/antec/blue%20power2.gif
now with Ninja :banana:
all case
Ninja
My baby. Not finished yet. But working on it.
http://home.earthlink.net/~brukla/im...6/DSC01542.JPG
http://home.earthlink.net/~brukla/im...6/DSC01549.JPG
http://home.earthlink.net/~brukla/im...6/DSC01605.JPG
http://home.earthlink.net/%7Ebrukla/...6/DSC01558.JPG
The project log is in the signature.
Will post final images when the system is done. And I know its messy but what the hey.
Wow, copper pipes?
The look of that copper piping is wicked....
Cooper Pipes... Is diferent of what i normally see...:wiggle:
Well I like the look of copper pipes. Pain in the butt to solder sand and clear coat though.
Originally Posted by jaguarking11
But its very unique! Props to your coolness!:p:
Mine......simple setup.....Mushkin high performance 2x1GB on its way to my setup....whahahahahah
http://img.photobucket.com/albums/v4...5/P1000797.jpg
http://img.photobucket.com/albums/v4...5/P1000796.jpg
http://img.photobucket.com/albums/v4...5/P1000795.jpg
http://img.photobucket.com/albums/v4...5/P1000794.jpg
AnthraX3D
nice and clean internals
gratz
^lol is that a thermaltake beetle? and also anthrax3d where did you buy that case, i have to have one
Yep thats ThermalTake Beetle, what do you me anthrax3d?
the Case is ThermalTake Kandalf Bought here in The Philippines!
