:up: way to climb the ladder ppl :D
:D Damn! I need that 32bit Windows now! Negative temperature outside would be also nice! :p:
My goal for today ... 18.4k
That should be nice for single(chip)-card on AIR ;)
Keep up brilliant work guys!
Well figured I throw mine out here again. Its not that impressive overall but it is for a 3870x2. Also this was run with my finel Prime stable setup 24/7 settings. This was on Windows 7 with the beta drivers as well.
Ph920 3550@1.45v
HD3870x2@890/955
3Dmark06 - 20075
http://service.futuremark.com/compare?3dm06=9761840
http://i303.photobucket.com/albums/n...b/Capture2.jpg
http://i303.photobucket.com/albums/n.../Capture-2.jpg
:up:
With phase, single 295 and Giga 790GX board...
http://img265.imageshack.us/img265/6...shot006dh9.jpg
OMG what a CPU score with NV card in the system :shocked::shocked:
Projected CPU score with NV card at 6Ghz is astonishing 9000 pts,that's i7 max OC territory lol :D
Nice score Dumo :up:
why are AMD boards cpu points so low in 3Dmark06 ?
do we get more GPU points on AMD boards vs Nvidia boards ?
lol :wth: getting about 2000 pointless when OC to 6.0ghz on AMD board vs nvidia board by that thought (informal).
or video cards are change the cpu points :wth: still lost. lol
dumo can u post system specs and 3dmark link
thanks nice score btw:D
21568
3.84ghz 1.52v
320 HT x 12x 6x HT @ 2241mhz 9x @2880mhz
SM2.0- 8237
HDR/SM3.0- 10728
cpu- 5709
http://service.futuremark.com/compare?3dm06=9762867
Attachment 93459
Thanks Msi:)
940 0849DPMW
Giga 790GX DS4H
2X1 Micron Tech. 6400 C4
GTX 295
Zippy 1200W and Single Stage cooling
http://service.futuremark.com/compare?3dm06=9761450
in a stunning upset nvidia takes the lead:rofl: been a long time here
Can't win :shakes:
XP gives better score, but restricted to two gpu's
Vista allows more then two gpu's but drags down the scores
Has anybody tried to run 3DMark06 with Win Se7en yet? I'm hoping they got it right this time
3DMark06 22013
SM2.0 score 8072
SM3.0 score 11766
CPU Score 5382
http://service.futuremark.com/compare?3dm06=9764064
Phenom II 940@ 3.8Ghz
M3A79-T
CFX 3x 4870's 750/900 512
4GB (2x 2GB)@1066
Vista Home Ed. 32bit
Cat 8.12
hmmm... I just noticed only one stick of ram is working
Holy :banana::banana::banana::banana: I just took the number 2 spot ......I think:confused::D:p::confused::shrug::D
3DMark Score 22187
SM 2.0 Score 8701
SM 3.0 Score 10974
CPU Score 5710
AMD Phenom II 940 @ 4.18ghz
Asus M3A79-T Deluxe
2X 2gb G-skill 1066
Sapphire 4850x2 @ 700/1150
4850x2(single card)
http://service.futuremark.com/compare?3dm06=9765859
OMG! What have you done!
Now I will need second HD4870 just to be in top 10 :shocked:
Soon you will need DI or Phase to be there :rofl: I want cold-bug back :nuts: (joke:p::p::p:)
Back to work then. Stupid multi-boot issues :p: XP is comming ...
I held second for 29 mins. Unbelievable :shocked::ROTF:
I was going to update with new score of 22159 and then go to sleep
http://service.futuremark.com/compare?3dm06=9767217
Now I'm just going to sleep :shakes:
I guess I'll have to try again later
Thanks Ben
i want to say hondaguy ran it in both and scored better in vista but im not sure
http://service.futuremark.com/compare?3dm06=9772144
~18k Phenom2 @4066MHz, 2x2GB 1120MHz 5-5-5-5-15-2T unganged, single Hd4870 512MB 830/1180MHz, Asus M3A79-T Deluxe
Got my sleep in, now to try again
Did some tweaking to the water block
remove their restrictor
cleaned the burrs that were left behind from their machining
first results seem promising
http://i231.photobucket.com/albums/e.../newwater1.jpg
good results ppl, AMDDeathstar do you have a link for the last score:up::clap:
You ati guys are in trouble soon :p:, plus I don't want to compete against DUMO, I'll get spanked.:D
