There's one pin on the C2D, THERMTRIP#, that deals with temperature issues, but that's for overheating. Basicly, when the cpu gets too hot, the technology shuts down the processor to preserve the quality of the silicon. If I'm not mistaken, first the clock frequency goes down, then the Vcc is shut down.
Here's what the Intel whitepaper says:
In the event of a catastrophic cooling failure, the processor will automatically shut down when the silicon has reached a temperature approximately 20 °C above the maximum TC. Assertion of THERMTRIP# (Thermal Trip) indicates the processor junction temperature has reached a level beyond where permanent silicon damage may occur. Upon assertion of THERMTRIP#, the processor will shut off its internal clocks (thus, halting program execution) in an attempt to reduce the processor junction temperature. To protect the processor, its core voltage (VCC) must be removed following the assertion of THERMTRIP#. Driving of the THERMTRIP# signal is enabled within 10 μs of the assertion of PWRGOOD (provided VTT and VCC are valid) and is disabled on deassertion of PWRGOOD (if VTT or VCC are not valid, THERMTRIP# may also be disabled). Once activated, THERMTRIP# remains latched until PWRGOOD, VTT, or VCC is de-asserted. While the deassertion of the PWRGOOD, VTT, or VCC will de-assert THERMTRIP#, if the processor’s junction temperature remains at or above the trip level, THERMTRIP# will again be asserted within 10 μs of the assertion of PWRGOOD (provided VTT and VCC are valid).
Is a too low temperature "a catastrophic cooling failure" as well? :D
