yep..
htt boot up clock the same as htt clock
vcore as needed
ram @ 800mhz divider
nb did 1 fid 04
cool and quiet disabled
which processor do you use? 9850? normally that should be easier then with 9750, but perhaps using lower multi and higher htt would work better? wasn't able to test high multiplier against high htt with the 9750 myself of course, but who might know?
I found 05/05 Bios is much better then ealier ones, but i have not tested the newest beta
full bios template (exactly my settings, besides all the ram subtimings (which are more or less left at AUTO values):
Code:>HT Link Control:
HT Link Width......................... - AUTO
HT Frequency.......................... - 1,6 GHz
IH Flow Control Mode.................. - Disabled
HT Link Tristate...................... - Disabled
2x LCLK Mode.......................... - Disabled
Unit Id Clumping...................... - Disabled
>CPU Feature:
CPU DID.............................. - 1
CPU FID.............................. - 08
CPU-NB DID........................... - 1
CPU-NB FID........................... - 04
AMD CPU stepping..................... - P0
>DRAM Configuration:
MCT Memory Timing.................... - Manual
2T Mode.............................. - Enabled
Cas Latency Time..................... - 5
Pre Charge Delay (tRAS).............. - 14
DRAM RAS# Precharge.................. - 4
DRAN RAS# to CAS# Delay.............. - 5
Bank to Bank Cmd (TRRD).............. - Auto
TRC.................................. - 11T
TRTP................................. - Auto
Write Recovery (TWR)................. - Auto
Write-Read Command (TWTR)............ - Auto
TRFC0................................ - 195ns
TRFC1................................ - 195ns
TRFC2................................ - 195ns
TRFC3................................ - 195ns
Trdrd................................ - Auto
TrwtT0............................... - Auto
Twrrd................................ - Auto
Twrwr................................ - Auto
CS/ODT Pin Fine Delay................ - Enabled
Bank Swizzle Mode.................... - Enabled
Auto Tweak Performance............... - Disabled
Optimal Performance Mode............. - Disabled
>ODC Control Mode:
DRAM Drivers Weak Mode.............. - Normal
Output Drivers Comp................. - Normal
>Channel A:
CPU On-die Termination.............. - 300 ohms +/- 20%
DQS Drive Strength.................. - 1.00x
Data Drive Strength................. - 1.00x
MEMCLK Drive Strength............... - 1.00x
Addr/Cmd Drive Strength............. - 1.50x
CS/ODT Drive Strength............... - 1.50x
CKE Drive Strenght.................. - 1.50x
>Channel B:
>PWM Settings:
PWM Control.......................... - Enabled
CPU VID Control...................... - 1.40000v
CPU Vid Special Add.................. - Auto
CPU NB Vlotage Control............... - 1.40000v
CPU NB Vid Special Add............... - Auto
DRAM Voltage Control................. - 2.12v
SB PLL 1.2V Voltage.................. - 1.20v
NB Core Voltage...................... - 1.250v
NB PCI-E Voltage..................... - 1.170v
NB HT Voltage........................ - 1.270v
Genie BIOS Settings:
Timing Mode.......................... - Manual
Memory Clock value or Limit.......... - DDR 800
PCIE 3,4 State....................... - Auto
PCIE 2 State......................... - x2
CPU TLB Cache Fix.................... - Disabled
AMD K8 Cool & Quiet control.......... - Disabled
CPU Clock Ratio...................... - Auto
Spread Spectrum...................... - Disabled
CPU Host/HTT Clock................... - 267mhz
CPU Host/HTT Boot Up Clock........... - 267mhz
CPU Host/HTT Adjustment Gap.......... - 5mhz
PCIE Clock........................... - 100mhz
