Hi all!
I have finally gotten serious about OCing my q6600 with this board and I have found a couple of things:
I can reach 3.33ghz completely stable with vcore @1.3875 and 0.0 CPU offset. I have to have a target voltage of at least 1.4125 just to sniff 3.4ghz :( I'm currently running 9x370 cuz my memory is not of the OCing type and I want to keept it close to stock speed, therfore I haven't tooled around with CPU VTT past 1.4. Also I haven't found too much of a difference in the CPU GTLREF. In some cases different settings seem to help a little but I haven't tested it thouroughly. I was hoping to reach a stable 3.4ghz but I get a little more peace of mind with the voltage under 1.4.
How high can you safely raise the vcore and still get at least a couple of years out of your processor? Is it more dependent on heat than raw voltage? If this is the case I guess I don't have to worry, I have a zalman cnps 9700nt that is performing marvelously! When trying to calibrate speedfan for temp I found that I couldn't do it. The guide states that you can't have CPU temps below room ambient, but the 9700nt, according to uguru and speedfan, had the temp at 12c with an ambient temp of 17c! I have been wondering if my temps have been correct because under load in prime I can't get it over 44c. also, my pwm temps hover around 60c max, and my cores are all running below 65c. Are my low temps just the result of keeping my home in the mid to low 60's? (it's cold here in Michigan so to me 60+ Fahrenheit feels warm!)
Anyways, just my thoughts. I have been following this forum and have found it very helpful. Thanks everyone!
