:rofl:
ATI Tool isn't working under Vista at all currently. You'll have to wait for the next beta.
Doesn't work here :(
ran some benchmarks with my 2900 pro pretty good scores if i say so myself..
3dmark 01
http://i163.photobucket.com/albums/t...65654marks.jpg
3dmark 03
http://i163.photobucket.com/albums/t...otos/45613.jpg
i used the atitool 27beta2 to raise the gpu voltage to 1.250v all this with stock cooling
Nice going Solarfall!!:clap: Now off to raise the bar......:D
here you go brotha :D
http://i163.photobucket.com/albums/t...s/untitled.jpg
is there a program other than 3dmark 06 or atitool to test for videocard stability ?
If I loop all standard test of 3dmark 06 (without the cpu test) for 5 hours , 3dmark kind of exits (or hangs on a load screen) and my total pc hangs .
Is it maybe the constant switching between 2d/3d it has to do (changing voltages/speed of the card) ? Also i see on the futurmark site that they only recommend cat 7.9 not 7.10 . I am using 7.10 ...
my cpu and memory are both tested on primetests for 48+hours stability each .
when the screen hangs after so many hours 3dmark , the temps its on are normal and not high at all . it is however always on 2d speeds when i find it locked ,thats why i think something happens between loading of tests . Gaming gives me no trouble altough i dont game for 5+ hours , i even lowered the core for 3dmark but same thing .
Im starting to assume its a 3dmark problem (it wouldnt even load without the patch installed in the first place) , so id like to test with another program . :shrug:
sounds more like a problem with the system stability, ram or chipset most likely. Drop them down a bit and re-test gpu.
Hmm...
around 1 in 5 times I exit a game (any game), the PC will restart :-\
I removed 2gb memory and dropped the speed of ram to 400mhz 4-4-4-10 , same thing happens .
Besides , dual prime wouldv complained after running 48+hours if system stability was not ok .
Any other program to test videocard stability ?
could it be the constant 2D-3D switching for the ati videocard ? i noticed sometimes rivatuner shows 1.15V even when i am in 2D . clockspeeds are normal , 600/800 then .
Try the OpenGL Fur Rendering Benchmark
There's also Aquamark , the other three 3dMarks, and maybe one or two others im forgetting as I just woke up. Anyone?
Ok, im getting over 60000 in 2001 but i need to up my volts some more & ati tool wont lock in the higher setting 1.2v. is there some trick to this? am i missing something? My card is never going over 65c, im benching in my shed :)
Hello everybody!
I have a problem =(
I can`t raise VGPU in ATI Tool 0.27 beta before overclocking.
When I press "Set clock" VGPU become default.
How I can VGPU constantly by software?
Sorry for my bad English.
Hey Pantacle, I am having the same issue. Hope someone can help us out. I havnt had an ATI card since the 9600xt.
