Not many people recommend 120 pcie clock. Use 100 for the everyday overclock ;)Quote:
Conroe e6600
Asus P5b Deluxe Wifi
G.Skill pc6400 2GBHZ
XFX 7900GT
320GB SATA
120GB IDE
Zalman 9500CPU Cooler
Antec NeoHe 500W
cpu frq - 350
dram frq - auto
pci express frq - 100
pci clock sycro - 33.33 Mhz
Spread spectrum - disabled
Mem voltage - 2.1
cpu vcore - 1.45 (why do i need such a high vcore to get 350fsb ??? )
fsb termination - auto
nb vcore - 1.45
C1E - disabled
Ram timings: 5-5-5-15
Dram Write reco - 15 (default)
TRFC - 6 (default)
TRRD - 42 (default)
Rest - 10 (default)
Results : stable
I tried 355 FSB and it hangs while loading XP
Give 8x401 a go
using wat settings ?
vcore, ram voltage, nb vcore?
vcore 1.35/1.45 should do. Ram 2.0 or 2.1v and auto for the rest to start with. Mem timings 4-4-4-12 or set by spd.
Does the P5B-D have a working crash recovery like other Asus boards? You know when you choose too aggressive an OC at reboot it says Overclocking failed press F1 to enter setup.
It doesn't seen to work on my P5B-D, I've had to clear CMOS every time I hang the board up
BIOS 0614
No post using 401X8Quote:
Originally Posted by loc.o
Black screen
My 400FSB X 9 looks hard top acheive without increasing the vcore
Current status
cpu frq - 350
dram frq - auto
Mem voltage - 2.1
nb vcore - 1.45 (what is NB vcore, not really sure wat it means)
C1E - disabled
Ram timings: auto (CPUZ reports as 1:1 4-4-4-10)
Results : stable
just switch off your PSU and switch it back on
I haven't had to clear the CMOS yet :)Quote:
Originally Posted by Blue078
from the manual:
For system failure due to overclocking, use the C.P.R. (CPU Parameter Recall) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values.
• Due to the chipset behavior, AC power off is required to enable C.P.R. function. You must turn off and on the power supply or unplug and plug the power cord before reboot the system.
Humm.. turning off the PSU's switch has worked a few times not all the time thow, but after 520fsb it never seems to kick in. Clear CMOS is the only thing that gets me back in the action.Quote:
Originally Posted by Pyr0
holding insert when poweing up sometimes will clear a failed oc setting
Current
Bios: 706
cpu frq - 340
dram frq - 533
Mem voltage - 2.1
cpu vcore - 1.45 (why do i need such a high vcore to get 340fsb to be stable )
nb vcore - 1.45 (what exactly is nb vcore?)
C1E - disabled
Ram timings: auto
cpu-z reading 4-4-4-10 timing
Results@340X9: Stable.
Results@350X9: PC reboots while halfway 1M SuperPi tests
Results@402X8: Black screen
Anyone who got hold of a P5B Deluxe with P965 C2-stepping?
Another question: My good old P5WD2 Premium had the restart problem where the board would completely switch off on a windows restart and then switches back on after a few seconds. This happened from FSB 243 and upwards.
I heard the P5B shows this behavior even on a cold boot when overclocked. Is that true or is this limited to warm restarts?
Set manually dram speed to whatever but not Auto ( leave it below 800)Quote:
Set fsb termination to 1.45
may i know why ?
sorry to be rude. just want to understand more
where are those new 2 bioses?708 and 709
706 works for me perfectly :D
I think it was Anandtech who reported that 708 is beta and 709 will be the official for crossfire support.
You need more vcore. try 1.5V... 1.55V if you really want to have fun. and 1.6V if you want to live dangerously. I run 1.575 24/7 on water. 1.675 for benching.Quote:
Totally unnecessary for 350fsb.Quote:
Originally Posted by mion
Current status
cpu frq - 350
dram frq - auto
Mem voltage - 2.1
cpu vcore - 1.4625 (why do i need such a high vcore to get 350fsb ??? )
C1E - disabled
Results : sstable i nxp but fails super pi 2M (Not exact in round - 4th loop)
Current status
cpu frq - 350
dram frq - 700Mhz
Mem voltage - 2.1
C1E - disabled
Ram timings: manual (5-5-5-15)
Results : stable in xp (does this mean my ram is the culprit behind the fsb thingy?)
I then went for 351,352,253 (reboots in windows after 5 seconds)
Tried 401,402,403 (no change in settings except fsb and its hangs while i saved the settings in bios - restarts manually NO POST, just black screen)
Shoot straight for 405 fsb ..it should work ..
I also have a P5B Dlx here for testing and it doesnt post anywear in 360-400fsb..
wat about the vcore settings, ram timings, etc ?Quote:
Originally Posted by Shark-357
leave it as deafult and jump to 405 straight ?
No luck. Black screen. Hangs while i tried saving the settings (405FSB) in bios
Try to figure out your Ram's Max FSB it can reached by setting the ram Vdim to 2.4 and use a divder while adjust the FSB higher.
