Poparimiro - it's truly beautiful, isn't it? Thank you so much for posting this.
poparamiro, I recently bought one of those Denki beasts myself and I can only say that I have never seen or heard anything like it before. BTW, I measured the startup current right at 8.3-8.4 amps and it pulled right around 75 watts measured at a running state at full power. BTW, I wired the pwm control wires together into a pwm 4 pin plug, so you can actually use the cpu fan header to control fan speed with it. That was pretty neat, hearing that jet engine of a fan speeding up and slowing down according to heatload on the proc. I have each motor assembly wired to it's own molex connector, 1 rpm wire and the pwm wires into a 4 pin pwm connector and the other rpm sense wire I put on it's own 3 pin fan connector.
Yes, the best i've seen so far, the pressure is huge. I prepare an article with all the great bench fans out there, 250 cfm deltas, 260 cfm Sun Aces, Sunons, 6800rpm Papst and as many i can get.
we should start using lawnmower engines with aluminum fans and TRUE's clusters
Xien16, what's with that pink thing under the mobo? acryl+leds? nice sleeved heatpipe lol
Did I just hear "RAM clearance issues"? :rofl:
Well, more appropriate approach is "smoke on 8 pin cable and connector" :D
L.E.
@ gatecrasherlok - only for testing :)
Holy moly Poparamiro, thats gotta give some decent cooling but at the deficit of killing the silence.
Whoa Popa! twin 300 cfm's!!!
85W FANS !!!!!!!!! EACH :eek:
:eek:
what fans are they?
San ace 120 - 300cfm
They are only for testing coolers in extreme conditions, 86 watt/fan.
What heatsink do you use to cool the 86w fans? :p:
Yes, i did some testind with "ultra extreme TDP" (1.66vcore, 1.65vqpi and large FFT). Coper was convex lapped for max heat transfer from nehalem die.
Here you can see previous Copper vs Nh-D14 test.
I'm in love with this thing :D
http://www.abload.de/img/matterhornvvm1.jpg
Damn you Tommy. :)
I thought these were supposed to be arriving at the end of next month. Looks awesome.
Yes, that's right :D..........one of the few presamples ^^
http://www.abload.de/img/matterhorn77na.jpg
