hey sinison...
any night shots of that tj07 yet??
hey sinison...
What is this fitting? I'm going to order a pair of the 3870 blocks from EK soon, and that would look pretty damn sexy, I cant seem to find this fitting on his site though....
EDIT: NVM, Google is my friend :rolleyes:
got rid of the soprano and here is my new aurora...much better...
with tygon R-3603.
it`s ot finished yet....i`m out of tubing..:D :D
@Giorgos th.
Looks great!
Keep us updated on the project and keep up the good work :up:
How about high end watercooling in a cheap bling bling case.:D
My case at the moment:
http://img144.imageshack.us/img144/1496/blue008av8.jpg
http://img170.imageshack.us/img170/4581/blue012oc1.jpg
http://img178.imageshack.us/img178/7596/blue044qj0.jpg
http://img401.imageshack.us/img401/6892/blue047vv0.jpg
Sorry about the crappy pics.:shakes:
http://farm3.static.flickr.com/2174/...70cdf415_b.jpg
http://farm3.static.flickr.com/2261/...5894c332_b.jpg
http://farm3.static.flickr.com/2112/...fc6a03cb_b.jpg
Still deciding on either t-line or reservoir.
NEvolution, how quickly does that T-line configuration bleed?
I was wondering what you were doing with the inlet not coming from any outlet, I was super confused until I read what you put :p
FYI I HATE the TT Armor WINGS/ears/front-flap-things. I have 5 of these cases and the first thing i do is remove the flaps :)
THere is a Thermochill PA 120.2 in there, with 2 Panaflo U1s on the back and 2 LED thermaltake 120s on the front for looks. I am using the stock Maximus Extreme chipset cooler, i know its restrictive but im runing a QX9650 @ 4.2 and havnt seen 50c doing a 24 hour prime95 FFT run with panaflos @ 70%!
http://www.dispensamatic.com/TTME1.jpg
Bleeding the radiator with the case upside down :)
http://www.dispensamatic.com/TTME3.jpg
http://www.dispensamatic.com/TTME4.jpg
http://www.dispensamatic.com/TTME5.jpg
http://www.dispensamatic.com/TTME6.jpg
http://www.dispensamatic.com/TTME7.jpg
http://www.dispensamatic.com/TTME8.jpg
Notice i removed the big 24CM fan, but it leaves plenty of air into the case.
Nice setup :)
Nice looking rig there!
I like the red/black theme and all the attention to detail: nice look :)
>Originally Posted by systemviper
>Hi, I am building a rig using he same case, I hope we can chat as i go >through the process, it's always great to have some experience to help.
>Regards
>steve
No problem! Be glad to help. Preparing the case wasn't hard at all.
I removed the 3 HDD holder in the front lower portion of the case to make room for the radiator (Thermochill 120.2). I screwed 4 standoffs into the 4 holes on one side of the thermochill and then using 2 of the pre-drilled drive bay holes (they line up prefect) for the front of the radiator, and drilling the other 2 for the rear standoffs (into the drive bay). FYI i used the fan from the HDD bay i removed (and one from another case) for the FRONT of the radiator for looks, and it does increase the airflow versus just having the panaflos pushing into the back. I also removed the foam dust collector pads that were in the front drive bay covers to increase air flow (and looks).
We tried mounting the pump several different ways, but the best method we found was using 2 layers of 3m automotive trim tape on the pumps back. This stuff never lets go. As you can see i bought some 1/2" elbows for the pumps outlet over to the bottom of the radiator. Another thing i did, which is optional: I use a 700w thermaltake modular power supply which has a fan on the bottom. This fan is blocked by the rear-top HDD bays. I turned the power supply around so the fan faces the back of the case, and then cut a matching hold into the aluminum case side. Just by freak coincidence we have a C02 laser (My dad has extravogent hobbies) so i cut 1/4" Plexiglas with louvers for air intake to fit the hole and make it look nice. I also cut Plexiglas to mount the swiftech reservoir as you can see in the picture. With the laser we can cut anything wood or plastic up to 1/2" thick, it just needs to be a Corel-Draw X3 or autocad drawing. If you like i can cut another swiftech mount and mail it to you for free, it only takes a few seconds to make.
More pics
http://aycu22.webshots.com/image/364...5347209_rs.jpg
http://aycu40.webshots.com/image/395...1238847_rs.jpg
http://aycu02.webshots.com/image/395...4192489_rs.jpg
Didn't resize these....
http://aycu04.webshots.com/image/388...7549067_rs.jpg
http://aycu38.webshots.com/image/382...6647295_rs.jpg
http://aycu35.webshots.com/image/370...5561605_rs.jpg
Nice setup binormalkilla. Keep going !
