Thank you very much that you noticed it, i have not noticed it untill you metioned it.
I changed the outlet with the inlet and the temperature dropped down, thank you again.
Looks good but the optical unit sticks too much in front.
Hey CD, what case is that? it looks very similar to what VoodooPC is using on their new case...
The case is an Antec NSK 4400.
Thanks, I do have different case, mine is PC G70, but very similar to yours, power can go up top or bottom, but dont think my power supply will fit up top with my rad, but maybe. I will have to do some mods no matter where I put it, but up front is another idea, thanks for the pics.
CyberDruid nice pump
Wow that's pretty funny hearing my $50 NSK4400 looks like a Falcon NW :ROTF: Not that I mind...
Yeah I know the ODD sticks out..damned drive is 1/2" longer than most. I was too cheap to get a shorter one and the client didn't care.
I am definitely going with the "Neopolitan" reservoirs next time: three loops is the bomb.
CyberDruid............. NICE
have to ask out of jealousy.. is that tubing bigger than mine :(.. lol what size tubing is that that looks awesome .. nice job.. you seem to be one ofe the very who who are consistent with each new build and dont go overboard/overkill.
Really like your work man keep it up.. to all other viewing this thread you can learn alot from CyberDruid
Kreuml, what cards are those?
I've never seen a card with only a single 8-pin connector.
wow sexy/clean rig you have there :)
I like those blocks: very "het" :D
@Darren: thanks but I swear it's only 1/2ID 3/4OD: the case is tiny! Makes everything look huge...
here's a lil update from today. gonna mod my maximus 2morrow cause there is not much time left.
looks a bit messi for now but enjoy ^^
http://www.gwebspace.de/sargatanas/PC/front.jpg
http://www.gwebspace.de/sargatanas/PC/mainboard2.jpg
@Disruptfam, I really like you new build!! It looks so awesome and very unique!
@CD, you build custom cases for a living or something? Your really good at it!!!
You've all inspired me to post some pics of the build my dad and I just finished...
Here ya go:
The casing is a bit messy with finger prints, but oh well..
http://img511.imageshack.us/img511/4640/cimg4206sk7.jpg
Here she is with the lights...
http://img85.imageshack.us/img85/2959/cimg4207ks1.jpg
Heres the 20.1 incher, we kept this from our old build (sorry for blurry pic)
http://img84.imageshack.us/img84/3248/cimg4208ru5.jpg
Heres our mini res/filltank
http://img515.imageshack.us/img515/3711/cimg4211ex5.jpg
And the big res... 1.5 gal.
http://img409.imageshack.us/img409/4963/cimg4212yl9.jpg
Heres our custom built temp watching thingy :). It shows the CPU, NB, SB, GPU's, in and out coolant temps etc.
Top ones the CPU, second is 1st VGA, third is the 2nd VGA, forth ones the NorthB, fifth is SouthB, and sixth is water out temp. (the rad tells us the water in temp.)
http://img136.imageshack.us/img136/9100/cimg4209ld5.jpg
Also serves as our power button :) (the button is from a Honda S 2000)
http://img253.imageshack.us/img253/1279/cimg4216gd5.jpg
Heres our rad. (it's the old Corsair Hydro Cool 200EX, still works great!)
http://img443.imageshack.us/img443/7216/cimg4222el3.jpg
Heres another pic of the inside (I know, it's a bit messy)
http://img410.imageshack.us/img410/6996/cimg4220xo8.jpg
We w/c'ed all the main stuff, both VGA's, CPU, NorthB and SouthB.
http://img81.imageshack.us/img81/7907/cimg4223gt6.jpg
Specs:
Lian Li 65 Series Case (it's an older LL case w/removable mobo tray)
Asus M2N32-SLI Deluxe
AMD 6000+
2GB Corsair XMS (PC-6400)
2x EVGA 8600GTS 512MB
Antec 850W PSU
Audigy ZS 2 Sound Card
Hydracool 200EX w/ 1.5 gal Acrylic Reservoir
Dell FP2001 20” LCD
Well, thats all for now fellas! :up:
Hi guys,
here's my TJ07 with the below sig...
Yes id also like to know about the clearance, just watched your case on youtube :D its good
Lloyd, turn the Fuzion 90 degrees so the outer barb is to the left instead of the right. I did the same error and after doing that, it doesn't cross now :)
Beside that, it's nice :)
Still tinkering and cleaning up!
Just figured out that i can use original tj07 HDD cage in the 5.25" bays without any mods or drills! Excellent!!
