Could you tell me MAX bench voltages for:
PLL
NB
FSB
SATA voltage
DDR2 REF Voltages?
PLL
NB
FSB
SATA voltage
DDR2 REF Voltages?
Is there any issues w/ mounting the Thermalright ULTRA 120 EXTREME on my new Asus Maximus Formula SE X38 ?
thanks!!!
I started having reboot problems, where this motherboard started in a non-stop reboot sequence. Pushing the clear cmos button did nothing. I had to remove the cmos battery to get it to stop.
Is there a fix for this?
And does the Rampage bios have this same problem?
Its rather ridiculous that such an expensive board would have a problem like this. I'm currently running the 1201 bios.
Hi,
I've just built me a new system: Rampage Formula and a QX9770. The system works fine and I wanted to overclock it a little bit, so I set the multiplier from 8.0 to 9.0 and Prime 95 ran for 10h without a single error. But when I switch my PC completely off (I switch the PSU off) and bott again I get the followin error:
"Error! The CPU to Bus ratio or VID configuration has failed"
I can then change the BIOS settings via F1 or load defaults with F2. If I choose F1 and change nothing the system boots properly and runs perfectly.
And the strange thing is: If i shutdown my PC and don't switch off my PSU this error does not occur. When I restart Vista the error does not occur, too.
The error also occurs if I just set the multiplier to 8, 7 or even 6 (but with "Auto" (=8) the error does not occur).
That's really strange, isn't it?
I use BIOS version 406 (but I already testet 403, 401 and 308) and have no idea what I can do to solve this problem.
I have seen that others here in this thread have the same issue. Here http://www.xtremesystems.org/forums/...postcount=4693 it is sait that the error occurs when all memory slots are used - I use 4x2GB of memory but I also tried just to use one slot with 2GB of memory and the error still occurs.
I also tried to increase the core voltage up to 1,35 but this did not help either. Can anybody help me?
Thanks in advance
//Edit: Here are the other components of my pc:
Board: Rampage Formula (Bios 0406)
CPU: QX9770
Memory:4 x 2GB OCZ Platinum XTC DIMM Kit 4GB PC2-8000U CL5-5-5-15 @2,1V
HDD: 1x WD VelociRaptor, 2x WD Caviar SE16 640GB @ Raid 0
GPU: Powercolor HD4870
PSU: Amacrox Freestyle 750W
CPU-fan: Noctua NH-U12P (with 2 fans in push-pull)
Further I have 5 other case fans in my Cosmos S 1000 but I didn't connect a fan to the "PWR"-connector on the board because in another forum I read that this can cause problems, too.
so hasn't the rampage extreme just come out?? if so wouldnt a maximus extreme to rampage extreme conversion work?? I'll be the gunea pig if someone will get me a file with everything needed on it so I can just extract it to a usb drive and go to town, hook me up guys, these maximus extreme bios really suck and are seriously limiting my overclocks I know my E8500 has way more in it!
well, i just got my mobo back from rma. giving it a quick run through right now :D
w00t! now to rma my dfi :(
Having a problem when i´m trying to unpack a dvd for example. It takes 7min 30s for a 4,3gb file. Doesn´t think it would take so long. what could be the problem ?? Running Vista X64
Turbo, are you running SP1 for x64 Vista? It increases file xfer rates tremendously.
well, im having troubles now benching at 545fsb :rofl:
rampage modded it straight away :P
i will get a 5.1ghz bench in tonight no matter what !
*edit*
also should i be worried that setting lowest available 1.5ppl results in 1.61?
Here you can find the latest chipset-drivers:
http://www.station-drivers.com/page/intel%20chipset.htm
What do these do in the BIOS:
DRAM Static Read Control: Enabled
Ai Clock Twister : Light
Transaction Booster : Disabled
-Relax Level 0
Thanks for any advice :)
Anyone using 2x1 crucial tracers either the 8000 or 8500 variant?
I have the older single sided D9's but I can't get them to boot.
If you do, what bios are you using? I'm on the 1201. Thanks!
Hi,
I just saw that you have a raid0 and I can tell you that the Intel Matrix Storage Manager increased my performance of my raid hdds greatly.
You can find the latest drivers here http://www.station-drivers.com/page/intel%20raid.htm
bye
