Originally Posted by
Zinthar
Are there any known issues with Seasonic PSU's (aside from the problems with the modular Corsair's) and the abit IP35 Pro? I have the Seasonic S12 650w and I'm starting to suspect that it is responsible for the completely random irreproducible bouts of instability my system has.
Following Ace's recommendations for BIOS settings and RAM timings to run 4 DIMMs I made the following changes:
FSB: 440x8
MCH: Upped to 1.48v
RAM: Crucial Ballistix 4x1GB DDR2-800
RAM Timings: 5-5-5-18-48-2T, 2.2v, running at 880 mhz
I can run memtest86+ test #5 for over 100 consecutive passes without error, and I had a 10 hour run of Prime95 blend that was successful as well. Then, suddenly I'll get a rounding error (it first occurred with the 768K test). I then stopped the test, closed Prime95, and re-opened it... multiple failures within a few seconds on the 1024K test. Continuous failure would occur at any uGuru settings (significantly lowering FSB to under 400 didn't help at all) until the computer was restarted.
Then later that night, my gf was playing World of Warcraft on my computer (a game which is fairly stressful on RAM) and the system just completely froze... no ability to Ctrl+Alt+Del or move the mouse. Event viewer in vista just noted the non-descriptive 6008 error.
So I can't get a handle on why the system would just randomly become unstable like this, if not a compatibility problem with my hardware. Do these problems sound like a PSU problem, or something related to tRFC being too tight at 48 or something??
