MF 1102 bios problems with s3
Can you comment on experience with MF1102 and S3 sleep state? I've read of some problems with some of the bios and would appreciate your first hand experience. Currently running with 907 and have problems with some hardware coming out of S3--CF card reader not recognized and MF included soundcard not working. No other real issues but I am not overclocking either.
Thanks in advance.
Still having 100% stability problems
Hello
I just swapped my 4x1gb Ballistix PC8500 ram to 2x2gb Dominator PC8500 ram to fix my system hang problems. But it still dident slove it I always get 1 crash when the system hangs and I need to force reboot no bsod nothing like that just freeze screen. I have been trying 1 millon settings and still no go I having the feeling that it might be a good idea to get a X48 moderboard but I am not sure. Always after 1 hang it runs fine horus after that the system is:
Q9450@3600mhz 1.23v(100% prime blend and small ffts stable even tryied OCCT ran smooth for 2 hours) max temp around 50c with realtemp it is watercooled.
Asus maximus X38 modded to rampage 0403 bios
2x Powercolor 3870s in crossfire only one with modded bios might this be it?, both run @850/1271 and I always get the damn atikmdag problem in same games.
Tagan Easycon 580watt PSU should be enough I heard alot of times.
3x hdds, 1x velociraptor 300gb, 1x 500gb WD sata, 1x 250gb WD sata
1x Samsung Dvd recorder
Bios settings:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency : 450
PCI-E Frequency: 103(tried 100-110 not diffrence over 110 and it dosent boot)
DRAM Frequency: DDR2- 1081
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 4
Row Refresh Cycle Time : 60
Write Recovery Time : 4
Read to Precharge Time : 4
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
DRAM Static Read Control: Disabled(tried Enable no diffrence)
Ai Clock Twister : Strong
Transaction Booster : 7 (tried alot of other settings but only boots in 7 otherwise blackscreen)
CPU Voltage : 1.23785v(1.23v load) (tried up to 1.3 no diffrence)
CPU PLL Voltage : 1.5v
North Bridge Voltage : 1.59v(tried from 1.4v-1.65 no diffrence)
DRAM Voltage : 2.04(2.1v real) (tried 1.90v and that makes the system completly unstable)
FSB Termination Voltage : 1.36v(Everest and bios says 1.26v so it should be fine or should I not trust Everest and bios?)
South Bridge Voltage : 1.5v
CPU GTL Reference : Auto(tried 0.63x but crashed on windows vista boot logo)
North Bridge GTL Reference : 0.67x( Tried alot of diffrent but still crashing)
DDR2 Channel A REF Voltage : DDR REFF
DDR2 Channel B REF Voltage : DDR REFF
DDR2 Controller REF Voltage : DDR REFF
SB 1.5V Voltage : 1.5v
NB LED Selection : FSBT Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
Plz anyone got any ideas är should I just sell the crap and by a P5Q that seems really good, plz guys I am getting crazy here and I dont really have the money to buy a new mobo, also forgott to mention both gfx and NB is watercooled max NB temp os around 40c max load and gfx around 45c load?
//Aqua
