Your cases are amazing LittleDevil, second to none.
Gorgeous !!
All your cases are beautiful, especially the carbon and white case.
Devil, I admire your cases! They are a piece of art and very neat and tidy - very good workmanship! It looks like you put in a lot of time to make your products the best!!! :)
I have 2 questions though: With a regular water cooling pump, they give off an EM field which may affect hard drives that are located right beside the pump. So it's usually advised to mount the pump far away from the hard drives as possible in the computer. Well I'm just wondering if the same principle would apply to the compressor unit? Would there not be some kind of EM field generated from it? I suppose it's still safe though because other people have obviously mounted these units into their V2000, but I was just wondering.
And the second question is, is there a start up period that is needed for the gas to cool down before the computer can be turned on be functional? Or could you turn on both the computer and the cooler at both the same time and start using the computer right away (while the coolant is cooling down)?
Okay, thank you!!! And keep up the excellent work!
Mike
@Mike44: You got PM! :)
These look awesome! :up:
LD i would buy a your phase.... When can i find you in msn?
BB
I'm getting a Little Devil Unit!! :D
Can't wait to get my hands on it, Little Devil is gonna fit it in a Lian-Li V2110 Case :up:
Very nice... i wish shipping would be reasonable for one
Make sure to post pics when you get it!
Another one for LianLi.
http://ld-phasechange.com/images/Nik...r%27s_SS/1.JPG
http://ld-phasechange.com/images/Nik...r%27s_SS/2.JPG
http://ld-phasechange.com/images/Nik...r%27s_SS/3.JPG
http://ld-phasechange.com/images/Nik...r%27s_SS/4.JPG
http://ld-phasechange.com/images/Nik...r%27s_SS/5.JPG
http://ld-phasechange.com/images/Nik...r%27s_SS/6.JPG
http://ld-phasechange.com/images/Nik...r%27s_SS/7.JPG
Best Regards
So small and clean looking single stage, good work! :up: :clap:
That's the first time we see a white colored compressor. Good choice! :up:
Beautiful!
Have You powdercoated brand new NL11F or that's normal, "wet" paint ?
Looks nice, only I'm not sure if flex hose won't be bended too much when evap will be mounted on CPU.
High temp wet paint.
Customer wants that suction line. 45° or 60° will be better.
Best Regards
Really nice build, once again! Good job! :up:
Just ordered one for my bro :)
Cant wait till it arrives :D
Selling it last i saw and heard
