I thought te 623-3 was pretty vanilla and wasn't good enough for real good overclocking?Quote:
huh? :stick:Quote:
Originally Posted by pentium777
GUys help me out here. I have a MSI K8N NEO@ PLat and cant get more than 1.5v in the bios no matter what bios I use 1.95 -1.98 and even a supposed 1.9 officical I found. The voltage options are totally fubar'd. I can get to 2.75ghz though not stable. MSI Users here??
I am very sorry to hear about you owning the MSI board :eek: Although I don't have anything helpful to say here other than maybe DFI NF4 Ultra-D? it is only around $129 for it I think, maybe I am wrong but MSI I haven't read anything good about latelyQuote:
Originally Posted by Gaspar
Business wise we have a class action lawsuit along with 1000s of other business for their 815 Mainboards and bad capacitors issue. We had literally 100s of hours in labor replacing those boards for contracted clients so it cost our company 10s of thousands of dollars for their cheap caps. Almost every board (MS-6309 ver 1) was leaking from the top of the caps resulting in random and or frequent rebooting. After that we switched to Intel Mainboards only
Well actually this board has been awesome for me untill the X2 cpu's. Its really only the voltage options IM dissapointed with really. I had a 55 that rocked, and I know this chip has some more room. As far as the DFI, Id have to also pick up a PCIex video card and I dont see any real performance gains from this over AGP yet. Id hate to have to get rid of my X800XT PE which still rocks.Quote:
I asked about this earlier in the thread but really didn't get much of an answer other then it improves scores in PCMark05 so i'm going to ask it again. What is it that the AMD X2 CPU driver does outside of just allowing you to use CnQ? I've seen user reports that it improves X2 performance in some applications/benchmarks. Why does it do that? Do most of you install it? Yay or nay?
http://www.amd.com/us-en/Processors/..._13118,00.html
Got single phase in but still need more work done. @ 1.52v I can only dual prime @ 2.83ghz -_-; CPU temp is @ 3c so I think more tweaking on charge, etc is in order (I did put more volt in temporarily to see how much more room I got only to find that temp do go up bit more than I thought -> actually reducing overclock).
Once I get matters resolved (different compressor to reduce noise and live tuning it with 1.7v or so to give it good temp under high voltage) I might have 3ghz dual prime rig... One thing is for sure, frigging thing is hot (My chipset temp gets to 52c, PWM around 60c at one point... gotta figure out ways to reduce this as it might be chipset temp that is preventing further overclocking..)
Gonna try out my 4400+ this weekend ... they finally arrived in Finland too.
*Edit* Picked it up... CCBWE 2505 UPMW. No testing untill tomorrow thou.
PTK
I think with that temp the best oc you get with Vcore between 1.5-1.6VQuote:
Originally Posted by jinu117
Which way has been proven best? I'm using a XP-120 with 120mm fan should I setup to blow air down onto the HS or should I suck the hot air off the HS? I've read both ways are good but wondered if anyone had proven this with tests here?
http://www.xtremesystems.org/forums/...ad.php?t=67198Quote:
xxmartin: What settings do you run on, that is the ldt, 3x, 4x etc? voltages etc?
For me: blow air down onto the HS.Quote:
Yesterday 2555 @ 1.45V was 54c for 10 minutes stable (had not more time to test). You have a bigger case and more fans, for you it must be possible to try higher Vcore :) .
2850 MHz (11*259) was with 1.450*110% (1.552V), memory @ 259 MHz and 2.7V + 0.03V, chipset 1.6V, ht voltage at 1.2V and LDT 3x.Quote:
Originally Posted by lv_88
thx, I've been running standard on bassicly everything (chipset, ldt voltage etc.) , except lowering the ldt to 4x, will go for 3x now that I'm at 270+fsb and see how it goes ;)
I'm going to try it and see if it makes any difference.Quote:
Originally Posted by burningrave101
@pentium777
Ready with your new sys? I'm waiting for your results, I wonna know how your setup will handle the heat.
It puts an entry in boot.ini that at least ocmark 05 looks for and maybe others. Doesn't hurt anything so might as well do it. (the exe version)Quote:
Farmer well, yes and no.... Last night I was exhausted and fell asleep believe it or not but woke up around 11pm and got some things done, problem is I have a rule of not keeping too much junk laying around so I had to prep the wife's system for sale p4 3.2 @ 3.5.Quote:
Originally Posted by the farmer
Now that it is out of the way I did get the opportunity to mount the mainboard, and fan, the Thermaltake Tsunami has 2x120mm fans and 1x90mm but they are weak fans :-( low cfm because too many people complain about noise. I've replaced the front intake with my panaflow 104 CFM 120mm, I was so impressed with the case I ordered 1 more and am going to use it instead of my server case.
I did also mount the X2 4400+ and got some AS5 on there with the massive XP-120, had to run a full backup last night of my box was 81GB so when I get home (5 hrs or so) I will be taking my main rig in the server case apart immediately, removing my OCZ 520 Powerstream and installing it into the Tsunami. I am hoping to get 5 more 120mm fans ordered today 2 for HSF for my rig and wife's rig and then 3 more to cover our intake and exhausts, only 41.5db so not too bad at all.
Unfortunately to my anger today Western Digital did not get my 74GB raptors to me for evaluation so I'm stuck with 36GB raptor, what I will most likely do is run a XP SP2 install tonight and fool around this weekend until Monday when they get here, so expect a lot of results this weekend. I am a noob to the DFI board so I don't even know how to tweak at all, most likely this will consume a lot of my time just learning all the ram settings etc. Plus coupled with being a noob AMD owner lol
I do believe I will have excellent cooling once all the fans are installed but we'll see how it does tonight with the ones I have available.
nicholarse,
How is that chip clocking right now? You said you are using the same air right? I will be finding out how good of a chip I received tonight.
10x260 on my x2 4200+ with a zalman 7000cu
With 2xPrime running, what Vcore and what are you're temps?Quote:
Originally Posted by LBJGH
Hi pentium, I've been so busy lately (mainly trying to shift some of my old kit - don't like living in a mess) so haven't had a chance to overclock the system yet. I'm currently using the stock amd cooler but have it running fine at 1.2V, I think stock is 1.35v?Quote:
I'm hoping to be able to get my watercooled stuff installed this weekend and finally get everything in a case (currently its all over my floor).
Will let you know how I get on.
Hi guys Just got my X2 4400..Stepping CCBWE 0524RPMW .
It will sit in the DFI Sli DR board with a Swifty 6002, bonniville rad, and the mcp 600 pump..A 7800GTX and 74 Gig raptor with some GSkill 4400 ram..Just waitin on ram and Video card ...
So far it appears no one has the same stepping processor..Any one notice that ?
Any one notice the heat pipe heat sink weighs a fraction more then the Processor LMAO...First time I felt a chip so heavy..And a heat sink so close to it in weight...Personally I think it is a junk sink,but thats just my opinion...
Any way I will have it set up mid week provided the last bit of stuff arrives by then and will post results of speeds and benchies ect..Bye Bye Dual Xeon...Hello X2...
:woot: :woot: :woot: :woot:
X2 4400+ @ 10x270, 1.535v with a Koolance EXOS and H06 block. Each core is 12.5+ hours P95 stable.
Damn thing won't budge above 2.7 at all though, even with 1.7v :mad:
