I just got a CABXE from the egg. hope its a good one..
Have people been consistently getting higher clocks on BH-5 and TCCD with San Diegos over FX-55's? If so I may have to make the switch :D
DFI ULTRA-D
3700+(0516WPMW)
TWINMOS BH-5(UTT)
TT SONIC TOWER
http://img98.echo.cx/img98/1114/kik7ek.jpg
Is that voltage right?
just picked this up. anyone with same stepping what was your results?
3700 sandy
cabge 0517 upbw
Holy $hit!....I second that...Quote:
Originally Posted by zxlr8
1.4Vcore -> Cpu @ 2880
3.37Vdim -> 1gb BH5 @ 262
Wow.....
In my head Peter Lu is known to get good hw ;)Quote:
Originally Posted by s7e9h3n
Hello everyone, I am new here. I think either my cpu has a weak memory controller, or y motherboard does not support it well yet. I have a CABGE 0517 UPAW 3700+ that I bought retail on an msi neo2 platinum mobo w/ xp90, and g.skill pc4400 tccd ram. I have latest bios by need.for.mhz, which is a 1.8mod that locks in 1t for san diego and other timing tweaks. even before this, I was able to run my old winchester at 280x9, with memory 1:1. Now I have my 3700@250x11=2750mhz @1.6v, with 166 divider to take ram down to 208mhz. 1:1 with ram at 250mhz isnt stable, 275x10 is far from stable :confused: I know the neo2 does not officially support the san diegos yet, and I have seen many people running 300mhz+ 1:1 on san diegos, but on different boards. so 1)is my cpu's memory controller weak? 2)do I just need to wait for a proper bios? or 3) do I need a new motherboard? (would be new dfi nf3) Thanks for any help or suggestions you could offer.
on the quality of 3700s that we can buy in the USA? I am getting the feeling that they are not any better than the POS that I have now (can get stable at 11x250 or 10x270 or 9x300or - you get the idea)
Tried 8 sticks of memory, 2 DFI boards and the best WC you can get and still POS. My luck that I would get teh one bad 0517 :upset: If anyone has a place in the USA that has something resembling something decent, please post here. Otherwise I am going stock and quiet and give up.
I can run 10x274 stable with 1.475 volts. it's all in the sig. exact same stepping, I wouldn't give up hope on it yet until u know for sure.Quote:
that s only 1M. for prime i think he have to set more vcore.
free
Well, I got mine yesterday. It's a CABGE 0516MPMW, and it seems to be utter crap. I'm not able to finish 3dmark 01 at anything over 240x11 (2640), and the most primestable I'm able to get, is 255x10, and this is with 1,65v :(
I only just got my Ultra-D too, so I don't have much experience with it. I'm using bios 6-18 on it now. Any tips? I really really hoped for more :(
Meh, I'm giving this chip up. It's impossible to stabilize it at anything over 2.55GHz. It's so typical that I had to get a crap chip. Dang my luck!
yeah i got luck with my first san diego had so much S754 and winchester cores... all no good but this baby rockZ 3200mhz is reachable and 3300+ suicide.
only one thing i got a messy mem. controller my bh-5 could do 282-2-2-2 but in with the sandiego it reaches max. 269 fully stable. i ll try my a-data tccd soon and let ya know the results.
seEn
try moving you dimms around. use orange, test and then swap the modules into the opposite orange and test. then do the same with the yellow. may or may not help, i gain about 3-5mhz in orange by swapping them to a certain place.Quote:
Originally Posted by andL64
I have a quick question what is it taking most 3700+ SDs at 250x11.0? Voltage wise...
I tried v1.350 + 123% and it wasn't stable...so I am not sure...I really don't want to give it too much being on stock HSF.
1,5V-1,55V or max. 1,6 if it cant reach get better cooling.Quote:
Originally Posted by ugp
seEn
Thanks...I am trying 1.500 + 110% It is actually pretty cool still...idling at 36-37C
Could too much voltage make it unstable?
no, but better temps for higher oc :D
i didnt really gain anything over 1,6-1,65V but this is @ 3200-3300
with 1,52V i get 3100 stable so dont gain much because temps getting worse....
seEn
Well I am sitting on 250x11.0 right now @ v1.55
And here is what I got...
http://xtremesystems.org/forums/atta...id=33354&stc=1
http://xtremesystems.org/forums/atta...id=33355&stc=1
What do you think...and it is a 30 sec 1MB SuperPi
well it worked :D ,thats good, just look here:
http://www.xtremesystems.org/forums/...id=33356&stc=1
this is with 252-2-2-2 very nice i think!
http://www.xtremesystems.org/forums/...id=33359&stc=1
here is spi1M @ 3190mhz with 245-2-2-2 (think so)
http://www.xtremesystems.org/forums/...id=33358&stc=1
here is PC2002 old but very nice just look @ memory and cpu score my mem. score increased very very much only with cpu speed.
http://www.xtremesystems.org/forums/...id=33357&stc=1
3272mhz sandra cpu-bench.....
i need some better cooling its with my modded mach2 (R290) when i get condensers i ll build my first single stage ondie cooling :)
seEn
It wasn't stable....:(\
Going to test 250x9.0 and then maybe 270x9.0...try to max out my RAM..
ok so try 1,5V +113% it should give ya about 1,568V or someting like that.
set ltd bus to 1,4V, and yes set some "ugly" ram divider like 166 for 250x11 so ur ram cant be the problem. i think the chip should at least do 2700-2800 with boxed at 36C
what stepping u got?
and just remember better temps will gain you much.
i also got some pre-tested venice with boxed @ 2,7 but it has the cold bug so i bought the sandiego next day :D have to get rid of this venice so its all bout luck.
seEn
ADA3700DAA5BN
CABGE 0518UPCW
1250228E50772
Um...does the LDT Voltage matter...I was reading that it doesn't...
And the RAM runs fine at 250x9.0 and that is what I had it in with my old DFI...
LDT has only made me unstable in the past, temps not being the problem. just depends on the board and chip i guess. test to find out! :toast:Quote:
