Haha I have two 2.7 GHZ winnies now but I learned the hard way - BUY IT FROM SOMEONE ELSE!! LOLQuote:
Originally Posted by Jupiler
Following that same philosophy thats how a got a good Venice!! :woot:
I've got the same stepping 3200+ as Charlie, week 15. GPBW I think it was. Dig up his thread in the extreme forum if you want to know for sure. Im xp120 + silent fan in a 95*F (I'm NOT exaggerating, looking at an outdoor thermometer setup on my desk right now) room. @ 2550 stock vcore now. And working my way up slowly.
Edit: Stock vcore with a bit of droop (~1.35v) I can do 2600-2633 stable. Bumped it up to 1.45v set (1.4v) trying 2666.
Edit 2: First time using a DFI nf4, and I've hit a very very strange wall. @ 2700mhz I seem stable, but @ 2733 Programs start crashing. For example, taskbar crashed on me. I tried bumping LDT volts to 1.3v, didn't help. Tried bumping Chipset volts to 1.6v, didn't help. Anyone able to help me out? I know this chip has more in it, and suspect I could hit 2800mhz prime stable with ~ 1.6-1.65v if I could get around this wall.
Edit 3: 2694mhz prime stable 1hr+ never errored. 2701mhz Prime error and/or program error and/or reboot within three minutes. Im almost positive it's something with the board, but 270+ fsb isn't stable with 10 multi and ram @ 166 (5:6). I'll try 9x multi later tonight.
edit 4: removed one stick of ram so Im running 1x512 single channel now. 2733 and climbing.
Edit 5: Looks like 2800 isn't out of reach single channel, but that's useless to me. If I find time tomorrow I'll go on a search for the best bios and try to get My HTT above 270 with dual channel ddr. I'm gonna toy with my new dothan now.
So i buyed to Venice 3000+
stepping: LBBLE 0516 CPCW :fact:
Z637478D50371
cooled with Hyper6
home temp: 26
CPU temp: 57
http://www.zone.ee/mardo53/Arvuti/Be.../31,266s.PNG?2
i gived 1,7v but its bit slower as that conf
http://www.zone.ee/mardo53/Arvuti/Be.../31,203s.PNG?2
i have bad mem, its D43 :rolleyes:
im bad in english :wth: :dammit:
Guys, I remember reading about some low multiplier bug which allows you to get some crazy 400+ HTT. Can anybody tell me what multiplier is that?
Originally Posted by arj
HTT to 2.5 is the best on DFI NF4 :toast:
I mean the multiplier. I think I remember reading before that the 4 or 5 multi will produce some sort of "bug" that allows you to get some very high HTT and to get a "legit" HTT, you need to use higher multi. What I would like to know the multi which causes the "bug" :toast:Quote:
Originally Posted by overcrash86
multi 4
but ram will run at a different speed than what is shown
I'm at 7x370 at the moment :D HTT multiplier at 2.
Chipset @ 1.49v (39C), CPU @ 1.34v.
just found myself a LBBLE 0517 DPMW with 0024 for the last 4 digits.. hopefully it's some good stuff
babyelf, please post resluts later ;) IMHO *PMW is the best stepping and *PAW too.
will do.. will have 3 to test
3000+ 0517 DPMW last 4 digit 0024
3000+ 0517 EPMW last 4 digit 0303
3000+ 0517 EPMW last 4 digit 0219
switched to 3/10 bios and dropped ddr top 150 (for testing) Im priming 2733 @ 1.55v (1.52v usual. Lowest I've seen in casual checks is 1.50v). This is with dual channel DDR. It's Just a hiar shy of 100*F in here today, so until I rig my a/c up. This is as far as Im going. I'm 90% sure I can hit 2800 prime stable with a bit more volts and less heat.
kinda high voltage dnotis for just 312*9....i need 1.485v for 311*9 :>
You have a very good chip Tedy. perhaps one of the best 3000+.
I will "soon" be there TEDY ;) Doing burn in now and will raise clock after I've passed 1h prime at my current speed :D
FINALLY found my problem.
Ram that did 250 @ 2.6vdimm on my old board needs 3.2vdimm to do 245 on this one. I hope gigabyte hurries up with my RMA. I like this ram and dont want to replace it AND my video card to keep this DFI.
On a good note, Priming away, just past 2800, at 1.65vcore. Gonna try and hit 2850, very very doubtful I can get 2900 prime stable on air, at least not in summer. I'm at 52*C now and I'm not going to buy a high flow fan just to test my chips max.
A/C is in now though so I might get my room down to 80 and lower that temp.
nope actually it isn't.....315*9 aint stable at 1.55v :(
i'm talking about voltages in bios...so this is 1.5v in cpu-z :>
TEDY, tried burn in there and prime after?
Originally Posted by TEDY
My 3200+ looks like it'd need ~ 1.675v real volts for 2833.
..and my BPEW need 1.40*110% (1.5V in Win) for 3056MHz to be S&M stable :D
http://wowgame.free.fr/3000+%20939/L...v3006.4Mhz.jpg
http://wowgame.free.fr/3000+%20939/L...v3000.6Mhz.jpg
http://wowgame.free.fr/3000+%20939/L...20et%20953.jpg
always same WC home made :banana:
but changed BIOS for 310 :D
And my Venice 3000+ LBBLE 0156 CPBW needs 1.5v real for 2.4GHz :mad: :mad: :mad: :mad: :mad:
Tried burn-in higherøx??
I was messing around today tring to go for high overclock since I have my airconditioning on and my computer over the vent, I tried higher vcore but still my computer just shutsdown... hope msi will release there new bios some time soon.
Anyways I figured can't go up lets go down, so I started dropping the vcore, the max I can drop it in windows with clockgen is 1.1vcore and I ran superpi 1 mil no problem lol at stock speeds but im goan see how far it will go at these voltages, temps are really low 30~ idle and +3c more for load. lol
When this motherbaord (msi neo2) gets to 21c it shows -1 lol
prime stable for 30mins so far
