my 7970 can't pass 3D11 over core 1270 (unlock bios)
Water Cooling)
Asus DCU2 TOP
Water Cooling)
Asus DCU2 TOP
Core i7 3930K@ 5200Mhz
MSI Lightning HD7970 @ 1400/1950Mhz
P48840
Attachment 130296
Core i7 3930K@ 5100Mhz
P13799
Attachment 130297
Jonik what do you use for cooling your Lightning?
EK-FC7970 Lightning Lightning water block.
All H2o cooling. Water temperature +18C:)
Attachment 130298
My Sapphire 7970 Dual X OC cards are at 1200/1600 @ 1.187v. I am getting some flickering on 3dmark11 and some red flickers. On the odd occasion it crashes. How can i make it more stable? Put some more v into it? What should i go?
1285MHz @ 1.25v, can't pass those mhz =/
Jonik try
Unigine Heaven X from HWBOT
http://91.121.148.119/downloads/hwbo...e_heaven_v103/
http://i.imgur.com/sgKhG.jpg
That it's the top of my card i think. totally stable with 1.35v on core :).
Regards.
Don't suppose you'd be willing to help me push past 1.35v on my Lightning would you?? Currently held back at 1340/1975 under water, temps are a non-issue at the moment, load temps hitting around 39/36/41 over core/memory/vrm.
If you can help I'd be more than happy to hand over my first born :D
My MSI R7970 Lightning. The card has not been with me long. I played around with her little and settled on this... 1200/1500 @ 1.250v. ASIC:78.6%
All benched at the benchmarks default settings:
3D Mark 03.....138372
3D Mark 05.....40516
3D Mark 06.....32330
Vantage.........37535 GPU score on P (performance) setting
3D Mark 11.....P9340
Heaven:
Attachment 130529
GPU-Z:
Attachment 130530
I will push a little harder once she settles in and we get to know each other. I don't want to freak her out so early in our relationship;)
3DMARK VANTAGE - PERFORMANCE
Asus RIVE
Core i7 3930K@ 5150Mhz
HD7970 Quad Fire@ 1350/1750Mhz
P74115
Attachment 130552
3DMARK11 - PERFORMANCE
Asus RIVE
HD7970 Quad Fire@ 1360/1750Mhz
P28546
Attachment 130553
driver 12.9 is super ;)
3DMARK VANTAGE - PERFORMANCE I got a lot of points with 12.9 vs 11.21
Core i7 3930K@ 5250Mhz
HD7970 Quad Fire@ 1370/1750Mhz 12.3
P29430
http://www.3dmark.com/3dm11/4660913
Attachment 130639
Next stage- CPU LN2 Cooling:up:
try the new 12.11 beta :eek:
P14789 marks with Radeon HD 7970 at 1370/1800MHz
http://hwbot.org/submission/2323485_
yes,an whit this driver I got 20/35 fps more in BF3 :D
hi,
12.11 testing on cf 7970 , good perfs but when I start sapphire trixx the pc freeze or bsod and ulps active ! no problem with AB but can not exceed 1.3v on gpu while with trixx is ok.
back to 12.4 and more trouble with trixx always a calamity ati drivers .
I USE not trixx ,but MSI AFTERBURNER
