just finished a 3DMARK-Vantage run with mem speed set to 2600:
http://i.imgur.com/Vv2ZW.jpg
Hi,
i bought this nice mem rig but need some help with OC.
Im running a 3570k@4500 Mhz..........and canīt go hiher than 2000 Mhz with this mem. It seems to my like a wall. No matter what i try, there is no post above 2000 Mhz.
Mainboard: Ga-z77 ud5h
Ram is running @ 1.47 V @ 9-9-9-28 T1 @2000 Mhz.
Settings Like 1.47 @ 11-11-11-28 T2 @ 2133 Mhz donīt post
Vtt Voltage is 1.100 V
IMC Voltage is 1.095 V
Any tip for my what else i could try ???
Thx
I have the same board, RAM & CPU & the below works for me @ 1.42v
Hope this helps
> Advanced Memory Settings
M.I.T\Advanced Memory Settings
System Memory Multiplier..........................[22.00
Memory Frequency (MHz)............................[2200MHz
Performance Enhance...............................[Extreme
DRAM Timing Setectable............................[Quick
Profile DDR Voltage...............................[1.50v
Profile VTT Voltage...............................[1.05v
Channel Interleaving..............................[Enabled
Rank Interleaving.................................[Enabled
> Channel A Timing Settings
M.I.T\Advanced Memory Settings\Channel A Timing Settings
Channel A Standard Timing Control
CAS Latency.......................................[10
tRCD..............................................[10
tRP...............................................[10
tRAS..............................................[28
Channel A Advanced Timing Control
tRC...............................................[39
tRRD..............................................[5
tWTR..............................................[6
tWR...............................................[12
tWTP..............................................[24
tWL...............................................[8
tRFC..............................................[128
tRTP..............................................[6
tFAW..............................................[2
Command Rate (tCMD)...............................[1
tRW Stability Level...............................[3
tWR Stability Level...............................[3
tREFI.............................................[6240
tREFIX9...........................................[54
tRRDR.............................................[1
tRRDD.............................................[3
tWWDR.............................................[3
tWWDD.............................................[3
tRWDRDD...........................................[4
tWRDRDD...........................................[1
tRWSR.............................................[4
tRRSR.............................................[4
tWWSR.............................................[4
Guys is it normal that for significant lower frequencies and (higher) timings a quite higher voltage is required for total stability on my Phenom X6?
Here is another stable run I pulled with mem speed on 2800MHz:
http://s13.postimage.org/mmqga1pxx/pifast.jpg
ruvio you have a very nice CPu! haha finally see my CPu isn't the best!!!! I am so glad someone else can do 5.3ghz with minor stability.
BTW you guys better hurry to buy these up, I went to MC and checked the site and it seems my MC is no longer stocking these, their stock went from 20+ on both the 4x2 and 4x1 and now is down to 4pcs and 2pcs respectively.
BTW I have this kingston ULV kit it is 1600mhz cas 9 just like these 1.35v and it seems to be going high as well, it is also a 4x2GB kit, but I do not think it is samsung IC.
Im using the same config, 2x4 GB in Slot 1 + 2.
They are Micron D9PFJ. Will do up to 2200 with good timings, but cant get any of my PFJs stable much higher then that.
Anyone know if other kits with heatspreaders are using 30nm Samsung ICs yet? I want to run my Ivy daily over 2400Mhz, but cant with my Microns, and I want "pretty" ram :yepp:
Picked up a 1149 dated set (they had two kits of 1149, wish I grabbed both). Posted right up 2200Mhz 9-10-10-28 1.6V, and running 32m as I type.
Anyone running these at 1600/1866? I don't want to bother with getting the most out of them.
I have two kits for 16gb. Having trouble getting my 3770k stable and wondering if it's the ram.
Currently set at 10-10-10-28-1t 1.55v
Hey BMW............ Try 2133 / 2200 10,11,13,34 1T or 9,10,13,32 1T all rest on auto apart from tRWDRDD to 4 @ 1.55v
My one set is stable at 1.4v 1866 9-9-9-24 1T
I don't have much luck after 2000 but 2000 is stable at 9-9-9-24 1T at 1.55v for me.
I do not have much luck getting anything higher stable however, then again I have not tried very hard. All my system volts are set to normal aside from 1.55v for ram.
Aftermath of extreme DICE session, voltages over 1.85V, and speeds of 2800MHZ++ :
this only happened to one stick out of the two.
http://i.imgur.com/2T1WS.jpg
http://i.imgur.com/yHPJq.jpg
http://i.imgur.com/3bjZE.jpg
http://i.imgur.com/CP0uo.jpg
http://i.imgur.com/5czaV.jpg
:clap::mad::D
:up:
My 24x multi wont post no matter what I try. The 26x multi works, and I got a Spi 1m, using 11-13-13 timings, but cant any more stable then that. Loosened Cas to 12, ran up to 1.65Vdimm, and pushed VCCSA to 1.1V, and it seems the more voltage or looser the timings, the less stable it is (doing that wouldnt load windows). Any tips what to try next?
@rouvio
What config you ran for 2400 MHz and 2600 MHz, 2x4GB or 4x4GB Samsung sticks? And what voltages, latencies? I see the mobo is Maximus Gene V, CPU is 3770K but can't see the number of modules you used and voltages, the pic is so tiny... Thanks in advance!
EDIT: I saw on previous page you ran 2800 MHz @ 1,72 V-1,75 V with 2x4GB sticks and nice latencies... Guess 2400 MHz and 2600 MHz runs are made with same setup. Was wondering how high can I go with 4x4GB with the same board and CPU?
@rouvio
Cheers!
I did try it earlier, but it wouldn't get any bigger so I thought you resized it and posted it like that... Works now, after a relog and cleaning of browser cache, soz for being stupid. :D
Any estimate how far could I get with 4x4 GB on the Maximus Gene V and 3770K?
Hey Sergio, I'm fine, thanks! ;)
Honestly, I don't know the difference ( or the advantage ) to the normal mounting, but there's article in the english wikipedia that explains the process steps.
I bought a couple of kits here in UK, ĢĢĢĢĢ's :shakes: to run in a M 5 Gene with a 3770K. (YKO 1214)
Steep learning curve cos I didn't do anything like this before and have not had a UEFI before either :rolleyes:
Hit 2133 on auto all I did was change to 1.5v (may go lower). I'm looking for a 24/7 2400. currently linX running at 1.6v (1.55 was not enough) lots to learn about timings yet so no screenshot.
Anyways, rouvio and the rest of you.... Do you think my aim is a reasonable one with these? and is there a good guide to ram timing relationships anywhere?
