videogamer323: yes, if you can, please do. No need to remove everything from plate of course. I'm guessing that it should be enough if heatsink mount holes/coolable mosfets/nearby elements can be clearly seen and to take pic at straight angle from side for Eddy or Niko to further deal with compatibility check. After all, heatsinkless pic part then can probably be easily photoshopped onto pic from vendor with heatsinks on.
