ghetto style :D
ghetto style :D
rc tweakit works for you ?
just order a new one i love this mobo
eh
how to use that iphone to connect via bluetooth
from app install to exact steps
anybody to guide here
raja??
Brian has a guide at the ROG forum.
http://www.asusrog.com/forums/showth...83#post2383%29
Guys, need some help. Just got my MIVE B3 replacement and am overclocking my 2600k on it. However, whenever I overclock 3 CPU cores disapear. This happened on 1101 bios so I flashed to 1485 - same thing. Never had this problem with this CPU on my old B2 MIVE... is there something im missing in these newer bioses?
MikeMk, did you check for pin damage on the new mainboard before isntalling the CPU? That would be my first thought as to the cause. I assume you have checked to make sure the BIOS option to allow all cores stays correctly set when you make the settings changes to overclock.
Yeah, it's set on all cores. I havnt checked the socket for bent pins, but wots strange is that all cores work fine at stock. Btw, sine my last post I've also noticed the over-clock doesn't apply. With multi at x40 in bios, in windows it only shows x16 and doesn't increase under load.
how to flash bios 1485?
i can't flash it:shakes:
but if i flash another bios i can do that....
"selected bios is not bios efi"can anybody tech me?
thx;)
problem solved;)
is it true that m4e need more vocre than other mmobo for same cpu oc ?
Well, got it all working now which is good... just beginning to realise how poor my 2600k is... looking like 1.4v for 4.6ghz :( Looks like I will be on the hunt for a new chip!
asrock xtreme6 5.4 1.63vcore in vantage ASUS.. 1.575vcore
an asrock xtreme6 max multi whit the chip x54,whit MaximusIV it is x55
I have my OCZ vertex 3 SSD connected to the red 6 GB sata port but what sata driver should I download to use the port?
Thanks.
To install Windows you don't need any drivers. In the BIOS set hot-plugging to enabled for the port the Vertex3 is connected to. Once in Windows you can install the Intel AHCI drivers. I use the 10.1.0.1008 drivers without issue.
Hi
i launch linX and i have this
http://img51.imageshack.us/img51/868...e146v75.th.jpg
Uploaded with ImageShack.us
but how to have more Gflop ? over 100 ?
my setup bios is : 1.455V and 75% loadine calibration and HT on for 5Ghz
Intel(R) 82583V Gigabit Network Connection
Network link is disconnected.
On this Max iv extreme is anyone getting this error under event viewer?
@ fab-45
Use the newer version of linpack from intel!
DL: http://software.intel.com/en-us/arti...pack-download/
and replace the files in the linX folder
@ all
Here's some updated bios from Shamino~
New 1407 bios
** Although it is marked as 1407 it is a latest -> newer than 1485**
Improved S3 resume
Upcoming Mem-TweakIT Support Added
http://www.freefilehosting.net/maxim...reme-asus-1407
thanks GaBBa-Gandalf
but i don't know how to install :confused:
Use the files from w_lpk_p_10.3.4.007.zip\linpack_10.3.4\benchmarks\l inpack and copy them into your LinX folder
thanks :up:
Hi
i put file in folder and ok
but i have a new BIG problem !
i can t be stable ! error 0X000000101 > more Vcore
i put 1.46V and test . . . bug , i test 1.50Vcore and bug ! lcc 75% and lcc 100%
occt is same
i don t change my setup in bios and now i can t launch linX or other program for cpu test now !
what is the problem ?
i install seven pack 1 this morning . . . is this ?
thanks
