bought 3 new chips from the egg
1 is a 5.2 stinker
2 is a 5.5 1.58v 32m 5.6 boots into windows havent played with it that long
3 is running 5.6 1.635v 32m :)
not too shabby
1 is a 5.2 stinker
not too shabby
Like cheapseat said gtx2 is faster than blade for almost 0,5s ( on same settings ) , will try to get gtx2 so I can compare myself.Also will try another bios just to see if anything changes in efficiency.Just got this board from store few days ago, no time to play seriously yet...
@Splave what batch/SN ?
Dont know if its any use to you but I just uploaded the GTX2 SPD if you want to try it
http://www.xtremesystems.org/forums/...d.php?t=267853
Yesterday and today tested six 2600K L045B387, one of them could boot and did wprime32/1024 - 5637MHz, another one boot only 5400. I tested with water cooling, when i found 56xx MHz chip, i changed type of cooling and used SS.
So I tested 14 - 2600K, 5637 was the best. The friend of mine tested 3 - 2600K and 3 - 2500K which he bought in USA(I bought all 2600K in Ukraine), the best was 2600K 54xxMHz, and one 2500K we won(Nick and I at MSI MOA Ukraine) =544x MHz max :down: So guys who found good chip and didn't buy at least ten cpu's are lucky :yepp:
Yep its really really lucky to get even 5.5Ghz chip -.-
This first 2600k of mine is L039B470 and maxes out 5480-5500Mhz. Once i get it stable on superpi with SS i can run Wprime 1024 at 1.5v@5.5Ghz.
But that speed isnt enough when ppl got over 5.8Ghz chips :(
Gonna buy fev more and try my luck! Happily i got more platforms to test with LN2 soon!
2600K
#1 5400 mhz
#2 5260
#3 5370.
I am currently out of luck.Ill try again after 1 month,maybe new batches appear,or my luck will change? :)
Awsome tread guys , wooow i just finished reading the whole tread and it is an open book for learning , thanks for sharing the knowledge guys :up:
working on efficiency. MIVE and CAS7 2000 Doms :up:
Now that is nice!! :) You finally find good hyper kit and board which is working with it. Waiting for final score :)
Good result... What memory did you use and vdimm , for those settings ?
Got a 56X Chip out of the first 4 I tried but after that it has been a long uphill battle. Have tested more than 30 chips after the first 4, and none of them have been able to match my earlier 56X chip. Best I have found out is a 55X. Got even a CPU with SN# XXXXXXXX300 which with earlier generations mostly would have turned out to be golden but it was just a 52X chip.
1485 worked better for you i guess :)
Had time to work on efficiency, high memory with 7-7-6-x rulz :)
http://forum.lab501.ro/attachment.ph...1&d=1303166336
Testing G.Skill 2133 8-9-8-24 on Gigabyte P67a-ud7 B3
2222 7-9-6-20 1T trfc 58
http://www.hwbox.gr/images/imagehost...f2375d1736.jpg
aristidis
bios? and green or black pcb?
1.85v
im amazed that they're not dead yet :D
Well done Aristidis and matose! Actually I think that Aristidis's run is the fastest @ 5GHz using PSC/BBSE chips :D
chip will not do 32m at .1bclk higher no matter what :) time to work on subs :eek:
