There is a 3d part of that build log that shows a bit more of that rad. So i guess that answers my question in post 559:
Its probably just a sample from months ago he's using up. Given the hype it would generate it would've been given more of a feature and hopefully more of a test if it was a release preview.
nahh... TFC would let him. Do you remember their reaction to the leaked admiral micro-site with all specs that was shortly closed with monkey face put instead. And now some guy just "accidentally" puts a engineering sample of a new top secret product into his vid... yeah that does sound fishy.
And i believe this is what happened: this design has failed to perform well despite all the hype around it (at least in the way Fester implemented it in its rads), but first eng. samples were sent out to its "partners" before it was discovered. So now there is no reason to hide it. Instead, why not create a bigger fuzz about it - so here you are folks, a freshly baked benchmark video.
BTW where did that modular design system go? That dual 120 rad does not seemed to be built out of two cooling units.
it's still there, watch closely (sidepanels are in 2 pieces) ;)
you can also see it in here
designing a case with four of these now
Attachment 117869
dunno... are you sure four is enough? :rofl:
OK, so it looks like a modular 240...when did he get it though? Is it part of the prototype that he "rescued" at CES or is it newer?
I'm sure Mark @ FCPU would royally pi**ed off if they are giving new Admiral stuff out to anyone but him or skinnee, he did bank roll the failure after all.
Hush, if skinnee gets his hands on those rads he might test and find out their performance and even make that info public. That might be not in best business interests of TFC. :)
Judging from the acrylic ends it could be newer version since almost the same design rad was spotted in earlier teaser videos by TFC
Yes it is dual-modular model. It is significantly different from sample I have seen at CES and it is still different from production model(s) as there further improvements were implemented.
I did some lazy performance runs on YouTube as part of my Orange build log. Works fine and seems has very little restriction to airflow comparing with traditional rads,... but I have no interest or free time to go into any serious testing. Triple rad would be better fit as you can see for the amount of hardware I have.
Sorry, i have no info about release date.
http://www.dazmode.com/_image/orange...abyte%20b6.jpg
