http://www.abload.de/img/dsc02093ec0s.jpg
A rare block with an exotic look, but i like it somehow :)
http://www.abload.de/img/img_5922y0w9.jpg
http://www.abload.de/img/img_5925i5f4.jpg
Just got some new Bitspower fittings :) Going to be redoing my loop and using all compression fittings and the Bitspower SLI fittings now. I have tried the Danger den SLI and the Koolance SLI fittings so far. The Bitspower look the best and the diameter of the tube is larger than either the DD or the Koolance so I like that as well.
http://img.photobucket.com/albums/v4...onFittings.jpg
http://img.photobucket.com/albums/v4...IBitsPower.jpg
http://img.photobucket.com/albums/v4...ss/GTX480S.jpg
Pic. Quote on same side ftw :)
The Dynamic Duo :)
http://www.abload.de/img/img_59894r71.jpg
bundymania
great job :up:
Are you using those as inline reservoirs or just to hold extra fluid? I would say the later since they are low, but I dunno.
The reason I ask is I got two of these for my build because my original thoughts were to run the fill port on top my haf into one of these then have it feed two xspc res tops through their fillports. That wouldn't allow for any movement of water through the FrozenQ res and would basically nul the point of buying a $130 res so I decided to get two and run them in the loop through the xspc reservoirs also.
Although crap that makes for another problem that I didn't think of until I typed it out. If both reservoirs are in the loop and not external from the loop I will never know the coolant level and I can run low. :-( :shocked: Now I don't know what to do with them. :shakes:
My noob question on that would be why two res's unless running two loops....and / or bling? :confused:
It´s just a test setup for a few hours (CPC´s , Restriction, different Adatpters before/behind quick disconnects and some Light Testing with cathodes and leds for another setup) , normally i only use 1 of those res. :)
Because I'm running two loops. My initial thought was to run the one frozen q into the two xspc res tops, but that wouldn't allow for the bubble factor in the frozen q because it would act as just that a res for extra coolant. I'm looking for the bubble factor and asthetics with the frozen q and the performance increase with the res tops. But now I'm at a loss because of what I stated earlier with not knowing what the level in the system is at. :(
http://www.abload.de/img/img_593106u3.jpg
Special Limited Edition
WOW.. that looks very very great :)
News from Taiwan :)
http://www.abload.de/img/img_60262wt6.jpg
http://www.abload.de/img/img_6029hkl1.jpg
made my "special LE" along time ago with some spray paint ;)
http://i45.tinypic.com/2l9t7js.jpg
http://i50.tinypic.com/wtf1h.jpg
Sorry missed the post, bought it from A-C-Shop.de back a couple of weeks ago, which they custom plated themselves. Excellent quality and service. :up:
Agreed, Jochen is a kind and fair person ! :)
http://www.abload.de/img/img_6031x3xn.jpg
Nothing special but I like this picture :)
http://img808.imageshack.us/img808/2346/img2070.jpg
