hey pphx459. nice to see another v2000 build, its such a shame they stopped making them!! it really sucks.....if i could id buy another 1:up:
keep up the great work!
pphx459 its a great build but those runs in the paint are sad. With the care you put into the rest of the build I can't believe you didn't take the time to correct this before assembly.
Just finished rebuilding my computer. Mainly moved my system from my MM H2GO case back over to my MM UF2O case, needed more room. I still have to finish the fans and clean up the wiring, but overall I am happy with it.
Components:
I7 920@4.2Ghz
Foxconn Blood Rage
2 x GTX280's
OCZ 1866Mhz RAM @ 1600 6-6-6-16-1T
4 x 150Gb Velicoraptors in RAID 0
Enermax Galaxy 1000 watt PSU
Cooling:
Aqua Computer Cuplex DI
Blood Rage NB Block
EVGA Hydro Cooler x 2
Thermochill PA120.3 for GPU's
Thermochill PA120.2 for CPU and NB
2 x Swiftech Microres V2
2 x MCP355's with XSPC tops
6 x Yate Loon Fans
Feser Red Dye and Distilled Water
MasterKleer 3/8" Tubing
BP Compression Fittings and Koolance Misc. Fittings
http://img521.imageshack.us/img521/8091/img1796i.th.jpg
http://img521.imageshack.us/img521/41/img1801.th.jpg
http://img521.imageshack.us/img521/9906/img1804.th.jpg
http://img27.imageshack.us/img27/744/img1805r.th.jpg
http://img27.imageshack.us/img27/778/img1807e.th.jpg
http://img27.imageshack.us/img27/543/img1810c.th.jpg
finally finished my system! just waiting for my 2 gtx 285s to arrive and it'll be complete, the iphone camera kinda sucks so ill have to do with these crappy pics til i can get my hands on a friends digi cam
http://img39.imageshack.us/img39/6607/pc3o.jpg
http://img41.imageshack.us/img41/6773/pc5m.jpg
http://img8.imageshack.us/img8/2343/pc8v.jpg
http://img177.imageshack.us/img177/8653/pc4.jpg
http://img40.imageshack.us/img40/1674/pc9z.jpg
pphx459 love the black/red theme. gj
pump: d4
cpu block: gtz
rad: mcr320qp
re: micro res rev. 2
mobo: asus p5q deluxe
cpu: E8400 @ 4500mhz
Wow everybody has some pretty Insane water rigs going on lately.
I just finished this little budget build up.
June i was planning a HaF , now Raven is here .. Ill have to Mod one of those instead..
I like to keep things very simple. This build was only done in two days, Needed another PC up and Going Besides my Oc rig .
Easy budget build. Nothing fancy .
http://i168.photobucket.com/albums/u...erbuild023.jpg
Small work log .
http://www.xtremesystems.org/forums/...d.php?t=225269
here is mine
just finished it recently
http://www.imagesforme.com/out.php/i516011_rad.JPG
http://www.imagesforme.com/out.php/i516010_pump.JPG
http://www.imagesforme.com/out.php/i...espowervga.JPG
http://www.imagesforme.com/out.php/i516013_sideoff.JPG
the wc parts are:
- swiftech mcr320 qp with 6 s-flex f push/pull
- ek supreme
- 4870 with ek full cover waterblock
- swiftech microres
- D5 vario
i did my best with the cables (didn't want to cut my case)
My Cosmos 1000 WC
Inside:
http://i88.servimg.com/u/f88/12/28/59/70/inside10.jpg
All
http://i88.servimg.com/u/f88/12/28/59/70/inside11.jpg
http://i88.servimg.com/u/f88/12/28/59/70/cosmos10.jpg
http://i88.servimg.com/u/f88/12/28/59/70/full10.jpg
Pump
http://i88.servimg.com/u/f88/12/28/59/70/pump_210.jpg
http://i88.servimg.com/u/f88/12/28/59/70/pump_110.jpg
@ MaxHardware
now that is sweet bro, props to you, love the colors.
that is gorgeous, MaxHardware.
First water cooling build-
http://img7.imageshack.us/img7/8250/image048b.jpg
http://img43.imageshack.us/img43/3294/image049c.jpg
http://img10.imageshack.us/img10/8610/image050tjz.jpg
http://img34.imageshack.us/img34/8969/image052j.jpg
i7 920 3850A795 D0 @ 4.2GHz
EX58-UD3R
G.Skill 3X1GB CL 9-9-9-24 1600MHz NQ
Hey Maxhardware, Nice build, great job :up:
Do you notice any difference in temps with 90 elbows on the pump inlet vs without?
@ ArcticOC
very nice, very creative to mount the rad to the bottom :) like your rig alot, very clean for having three rads :up:
This is what I have managed to come up with so far.
http://img199.imageshack.us/img199/3...olingpub01.jpg
miller thats a very nice setup man :up: with some sleeving, it'll look alot better :)
The whole rig, and final result :)
http://www.diskusjon.no/index.php?ac...post&id=304017
http://www.diskusjon.no/index.php?ac...post&id=304018
very nice artic, looks superbly clean :up:
My Rig PC-343
Attachment 97744
Ride Side: 600W PSP 15V meawell For TEC, 1000W Strider, TMS-200, and Mini ITX Board
Rads GTX 120, GTX 240, and GTX 360
Attachment 97742
Left Side: P5Q, Q9650, ATI 4850, 4 ddc 3.2 pumps - two w/ petra's tops and two w/ xspc tops and 320W 13.5V meanwell for overvolting pumps and fans
Attachment 97743
Attachment 97745
Been lurking for a while thought i'd throw this up for now.
XSPC-Restop/Swiftech 350>XSPC RX120>RX240>HK 3.0 LT>EK FC285
Any suggestions on making it better? I realize the tubing between the GPU and RES is kinda long, but it helps with i'm trying to take things apart.
http://inlinethumb61.webshots.com/45...600x600Q85.jpg
http://inlinethumb29.webshots.com/44...600x600Q85.jpg
http://inlinethumb54.webshots.com/31...600x600Q85.jpg
http://inlinethumb26.webshots.com/18...600x600Q85.jpg
^^ damn, I like yoursetup a lot man, great job :up:
