Wonder how they got the CPU temps on the AMD CPU, I had 2 mobo's to try , the core readouts are pure crap on this AMD CPU and the biosses both reported temps sub ambient temps... Really weird it can't handle the AMD
Some weird stuff :
"much quieter Corsair H50 that uses a single slow spinning 1,500rpm fan" : Mine both do +1600rpm
"As a result, even when we set the Corsair H50 to draw air in from outside the case the system ran very hot" : So the rad gets fresh ambient room air, two top fans suck out the hot air and it still performs better than when the inversed the flow with an extra heated cpu block... System temps get hotter which is logic as hot air is dumped inside the case... but it get's beaten by the stock cooler ? this due to lack of normal airflow ? C'mon. Even when you reverse the flow the fan doesn't suck air out as good as a normal fan due to air has to pass through the radiator fins, system temps overal with the H50 will be higher. It's due to the Cosmos design he says, if it doesn't have any intake fans how can the air coolers be so much betterthen ? as no fresh air is blown into the case... underpressure ?
I couldn't boot at 3.6 with the stock cooler and 1.45Vcore, with the H50 I could enter windows run and prime, (but can't read out temps correctly)
