Originally Posted by wreckage
Why do you keep saying i should set bclk to 195? I've said like 2 times I cant boot any higher than 193..
Bclk
190 = stable
193 = unstable
194 = impossible
over 194.. always sais LOCKED on LCD Poster, never got a DET DRAM message
I got a little closer according to the LCD Poster tho, 1 time it booted with 194.. but the CPU was running at 14.13GHz , the other times it showed DET DRAM and CHECK CPU, maybe 10-15sec between them.. but well.. there is some magic über wall between 193-194 for some reason
Tried bios 0804 & 0805, cpu voltages between 1.35 and 1.5, QPI 1.35 to 1.42, IHO 1.3, 1.65v mem, uncore always twice memory, removed 1 memory, HT&Turbo on/off.. it only booted 1 time.. and it said the CPU was running 14.13GHz so.. fail
Im currently running:
HT & Turbo: On
Bclk: 190
CPU: 3990MHz with 1.312v
Memory 1527MHz 8-8-8-24-1T 1.65v
I could run 180 bclk (3.8GHz) and memory at 1800MHz 9-9-9-26 maybe?
Still why wont it boot with anything above 193 bclk.. like all people in this thread have done it
Edit: Tried TurboV now.. changed from 190 to 193.. worked fine.. then.. BAM 194 the ultimate number of doom.. it worked for ~~ 7 seconds, when i moved the mouse it "lagged" frame by frame = something is very wrong with BCLK 194+, could the motherboard be broken somehow? Because I payed alot of money and I expect to get over 193..
got that problem to..192 is all i can go ..........getting the LOCKED on bootup
