Is Box cpu.:D
The cpu is stable at 4010Mhz with 1.20v.:)
http://img126.imageshack.us/img126/9...2076ex5.th.jpg
Very good!:)
what about small fft's ? :D
Metroid has a C0/C1 as well..
I am having problems tranferring files on 64bit Vista it's taking like 1 hour and 15 minutes to transfer 35.0GB of music anyone known why that would be??? Am I doing something wrong I am using WD Velicoraptor for my operating system and tranferring files between 2 Seagate 1TB drives internal..
What does this inf utility do?
damn here goes the batch lottery again... reminds me of the good old E6600 days... mine was from a good batch but it still sucked. :rofl:
hope this time i get a decent chip. :p:
i920 3838A554 here but it needs at least 1.325v for 4ghz prime & HT it seems.
I've only got 3.83GHz here and I am on air cooling. Still I'm happy because it's much faster than my Q6600. Also I've finally got SLi on an Intel platform with massive bandwidth to boot.
You have not installed it? The older ver. is on the P6T CD for the x58.
You want to use the -OVERALL command found in the readme.txt
-OVERALL
Updates ALL INF drivers on all available devices
even if third party drivers are currently installed.
This flag works in Interactive Mode only.
I created a directory called Intel. I placed the update utility in there. And created a shortcut. In my case C:\Intel\INF_allOS_9.1.0.1007_PV.exe -OVERALL
look, Intel uses 9.1.0.1007. Read your MB pdf.
You can OC all you want. The OS set-up is just as important for performance.
http://www.intel.com/performance/des...pec_config.htm
