BIOS 903
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Control : Manual
-Ratio CMOS Setting : Auto
FSB Frequency : 450
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: 1200
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 5
RAS# to RAS# Delay : 12
Row Refresh Cycle Time : 3
Write Recovery Time : 42
Read to Precharge Time : 6
(missing setting?: 3)
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Enabled
Ai Clock Twister : Light
Transaction Booster : Enabled
-Boost Level 0
CPU Voltage : 1.33100 | 1.312VCPU-z
CPU PLL Voltage : Auto | 1,65V Bios
North Bridge Voltage : 1.25 | 1.26V Everest
DRAM Voltage : 2.16 | 2.19-2.21V Everest
FSB Termination Voltage : 1.20 | 1.22V Everest
South Bridge Voltage : 1.050 | 1.06V Everest
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : Auto
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
Could lower VCore a bit and tested with prime custom in-place fft 10h without an error.
A few days I tested 1,325V VCore with OCCT "CPU" and had an error next day from OCCT, but a small error-window, like the windows-error-windows, lol. The test itself ran on till I stopped it after 12hours and no stress-test error. But this OCCT-error (sth like wrong address in A777Fccx0, but don`t know excactly), what was that? Is it stable, or not!?
