My daily usage is 8x513 = 4100 mhz large fft and small fft totally stable but When the system is idle sometimes restarting ! What's going on ? high fsb affect the hdd or something ?
Whats your SB voltage? When you Clock your FSB up your not always just
affecting the link between the CPU and the NB. The NB is the central hub
to every component on your board. Some things can be locked (i.e. PCIe)
to a certain frequency while others like the SB (responsible for Sata, Pata,
USB, etc.) will/can be a affected be the FSB Frequency. I have mine
at max 1.20v noprobs.
Good Luck..
Should I increase the Pci-e frequency ? default 100 .. What am I
do ? Sb voltage is 2.05 but same issue... When I exit the game it's restart
anyone ever use a x3220 Go in this board. If so how did it work for you. I had a X3210 and it was fine but for some reason a friend owns a x3220 and a P5k black pearl edition and is having trouble.
ahh sorry, It's already 1.20 :(
Any p5k-e users ? reach 600fsb with this 45nm cpu's ?
What BIOS are working well with 45nm?
Iv tried 0906 (no POST) and 1004 (hangs in BIOS)
Some people are having success with these BIOS...answers would be welcome!
My 8200 8x525 is stable orthos small fft but When I run the large fft it crashes , I think the mobo limit or bios issue (mine 1004) !! also windows opended at 8x535 no problem..
If it's not stable at 525mhz in blend then your ram sucks probably. Give it more volts and re-try.
Well... small ffts stresses only CPU while blend stresses both CPU and RAM so...
The system restarting at idle ! but orthos small and largee fft stable , what is the problem ?
I just ordered this motherboard. I was wondering if it would be a good idea to replace the TIM that comes with the stock board, with an application of Artic Silver 5 before I mount it in my case.
I'd be more than happy to share =)
I'm in the middle of a bunch of stuff right now so I can't reboot to look right now though, sorry for the delay bro =(
I'll reboot and take some pics ASAP, then edit this post or something.
--edit--
Here ya go, took some pics from the AI Overclocking screen:
Just had a thought about this. Did you disable all the C1E EIST (speed step mess). If not your cpu may be droping the vcore down (to save power) at idle to the point that it becomes unstable for your overclock. Just go to the
CPU feature section in your BIOS and disable everything in there.
Yes, speed step disabled . I'm using 1004 bios..
Asus p5k-e p35 chipset
E8200
2x1gb ddr 1066
250gb Seagate sataII Hdd (onboard sata controller)
x1950xt
pci-e frequency at locked 100
I use this config 8x500 daily usage .. orthos small and large fft totally stable .. But sometimes When system is idle windows restarting , I think hdd is cause this issue ... so Should I increase the pci-e frequency ?
I just got my Wolfdale 8400 up and running this morning. Here are some running on aircooling results
Mobo-----P5KE Wifi
Prossy----8400 Wolfdale
PSU------PC and Power Cooling Silencer 750 Quad
Cooler----Scythe Cooler with 100mm fan
Memory--2 x 1 gig G.Skill 6400 HZ
Vid Card--Foxconn 8800GTX
HDD------250gig Seagate Baracuda
DVD-----Samsung DVD writer
FDD----Sony
Vantec---Fan Contoller
http://img.photobucket.com/albums/v2...Zilla/pihi.jpg
http://img.photobucket.com/albums/v2...a/aqmk3wow.jpg
This board and processor are sweet together
WZ
What is the fsb strap to nortbridge ? what should it be ? my current setting is 8x500 ... system booting only when I changed to fsb starp to northbridge 400 ?
New BIOS 1006 - ftp://ftp.asus.com.tw/pub/ASUS/mb/so...-ASUS-1006.zip
Here are my bios settings at least for now. I have not had this thing in use for 24 hours yet. I will play with it more but, it is hard to argue with where I am at so far.
http://img.photobucket.com/albums/v2...a/IMG_4216.jpg
As you can see I just left the strap on auto.
http://img.photobucket.com/albums/v2...a/IMG_4217.jpg
Not running too Xtreme on the voltage settings.
http://img.photobucket.com/albums/v2...a/IMG_4215.jpg
Red Heat!:shocked:
Here is a list of my parts for my all air system.
Mobo-----P5KE Wifi
FDD----Sony
You know it was not probably necessary to buy that PSU but, I have just always wanted a PC&P.
WZ
