Originally Posted by
ust
Hi again matey;)
Sorry I can see what you are talking about. I'll try to express myself more thoroughly now...
First I tried to follow your 400*9 template, but Prime failed right away with those settings. So i bumped up my Vcore to 1.4250 and lowered the FSB Frq. to 389 from 400. With these settings, as said in my previous post, one core failed after 1 hour and 80 mins. while the other three went on with no errors for 52 hours.
Okay, back to present time. I'm advices by Supershanks and R*r to bump up my VTT and MCH, but decided to try out 9*400 again since it seem to be a sweetspot for the CPU judging from the countless OC threads here.
So I tried with a higher VTT and MCH to reach 9*400 and this is where we are now:)
With these settings 2 of the cores fail immidiately:
ABIT IX38 QuadGT
OC GURU:
CPU OPERATING SPEED................ - USER DEFINE
EXTERNAL CLOCK..................... - 400 MHz
MULTIPLIER FACTOR.................. - x 9
ESTIMATED NEW CPU CLOCK.......... - 3600 MHz
DRAM SPEED (CPU/DRAM)........... - DDR2-1:1.25 DDR2- 1000 Mhz
PCI EXPRESS CLOCK.................. - 100MHz
VOLTAGE CONTROL:
CPU CORE VOLTAGE................... - 1.4125V
CPU Core Voltage Offset............ - 0.00V
Target CPU Core Voltage............ - 1.4125V
DDR2 VOLTAGE....................... - 2.175V
CPU VTT VOLTAGE.................... - 1.42V
MCH 1.25V VOLTAGE.................. - 1.45V
ICH 1.05V VOLTAGE.................. - 1.20V
ICHIO 1.5V VOLTAGE................. - 1.50 V
DDR2 REFERENCE VOLTAGE............. Default
CPU GTLREF 0+2..................... - 68%
CPU GTLREF 1+4..................... - 67%
ADVANCED CHIPSET FEATURES:
DRAM TIMING SELECTABLE............. - MANUAL
CAS LATENCY TIME (TCL)............... - 5
RAS TO CAS DELAY (TRCD)............. - 5
RAS PRECHARGE (TRP)......... .......... - 5
PRECHARGE DELAY (TRAS).............. - 15
REFRESH CYCLE TIME (TRFC)........... - 30
WRITE RECOVERY TIME (TWR)......... - 3
WRITE TO READ DELAY (TWTR)........ - 3
ACT TO ACT TIME (TRRD)............... - 3
READ TO PRECHARGE (TRTP)............ - 12
COMMAND RATE....................... - 2T
PCIE Root Port Function............ - V1.0A
PEG FORCE X1....................... - DISABLED
INIT DISPLAY FIRST................. - PCIEX
ADVANCED BIOS FEATURES / CPU FEATURES:
THERMAL CONTROL.................. - Disabled
C1E FUNCTION....................... - DISABLED
EXECUTE DISABLE BIT................ - DISABLED
VIRTUALISATION TECHNOLOGY.......... - DISABLED
EIST FUNCTION...................... - DISABLED
