1 Attachment(s)
Day 6: AC-2 Testing (24hr non-stop operation)
Well I've been running this thing non-stop since Tuesday morning, and I am happy to report that all seems well.
Below I have attached a cut-n-paste from the chart that is running on a remote PC at work connected to 5 temperature points on the AC-2 unit (I am presently at home right now --- gotta love remote view software). Unfortunately our current version of test software doesn't support pressure read-outs, so the running pressures are: ???
The other problem is that the software crashes after a few days, and then I have to restart it (hence the 38:XX hour:min point listing at the bottom of the chart).
An explanation of the various temperature points being monitored:
Comp Dschrg = Compressor Discharge Line (within 2" of compressor body exit point)
Comp Suction = Well I guess this one is pretty obvious
Ambient = Air temperature of the AC-2's surroundings
Probe Middle = This is a taped on TC at the middle of the Evaporator Cold Probe (aluminum metal tape and several turns of black electrical tape)
Average In/Out = Feed and Return TC's on Cold Probe connection tied together to yield an "average" temperature across the probe (this will eventually be connected to a permanent panel mounted TC meter)
As can be seen; there is a little bit of oscillation in temperatures, but it is extremely small (worse case = +/- 1/2 degree C, even less on the cold end). If we were going to have an issue with oil freezing out, I'm sure it would have shown itself by now, with the cold end warming up considerably.
Keep in mind that I never changed the oil in the compressor, so it is most likely a standard temperature variety of AB as supplied by the factory. This would have a typical freezing point of -40 to -50C. Also there is no oil separator in use. This really shows how good the phase separation is working to return the oil, as well as the excellent miscibility of the oil with several of the refrigerants selected.
Mikey likes it :up:
2 Attachment(s)
Day 2: Open Air Test (no insulation)
Well it didn't turn into a 10 foot tall ice creature (I know you guys are disappointed), but it was very frosty.
Next and last test will be in the actual application. That being in a deep vacuum on a Helium Mass Spectrometer.
