if I may (again)
Attachment 73518
Attachment 73519
Attachment 73520
if I may (again)
Attachment 73518
Attachment 73519
Attachment 73520
nice THX amp :)
Sorry that's what i mean't to type nice Rotel THX amp :)
But i've always rated my Logitech THX speakers over the standard
http://img143.imageshack.us/img143/5394/ll1gd7.jpg
http://img143.imageshack.us/img143/433/ll3kc2.jpg
I know it has a lot of room inside. WC later.
Nice Setup
Hey, exactly how much room is in the top "compartment" in this case? I understand it fits a 120mm fan, but is there any extra room up there? Even a few mm will help me fit what I need up there.
Very clean btw. Have you thought of painting the rest of it besides the mobo tray black?
Its a tight fit man, with the PSU in the top there is 3.5mm left over. With a 120mm fan at the top maybe .5mm, it was a tight fit at the bottom for a 120mm fan I modded. I thought about painting the rest but didn't I will put a thin .25mm black isolating foam in the bottom for appearance and to block all of the little holes from air entering the case unfiltered. The case has great air flow with all 5 x120mm fans on low, its very quiet.
3.5mm as in 3mm and a half. or 1 3/8
.5 and in a half of a mm. or 3/16
I build that table myself. Got some wood and a couple of legs. Thats an copper GTX
heres mine ATM - most of the stuff on top bench is gonna go into another room soon tho :D
here's mine.
some "extreme" workstation :D
http://img207.imageshack.us/img207/5...0913nm5.th.jpg
this is after I made some cable "improvements", and added fans for cooling...
and changed my monitor for some LG 226WTQ, nice screen!
http://img230.imageshack.us/img230/6...agem000bh3.jpg
http://i18.photobucket.com/albums/b1...MG_05281-1.jpg
cables are a mess but will clean up once cables once PC is up and running again.
nice station lowfat, I really like your table! :) we're is it from?
Thought I would go ahead and post mine (click on it to view full size).
http://i143.photobucket.com/albums/r...h_IMGP3976.jpg
I used to have 3 screens but they were only 1440x900 and I would rather have a much larger screen with a much higher res with many more inputs and great speakers (which I didn't find out till I actually got it). Any ways I currently have my Comp hooked up via HDMI and my PS3 via YPbPr (also have HDMI cable ready if I feel the need to use that instead) and I also am going to hook in my Game Cube I think, at least till I get a Wii haha.
I would show my tower buuut it's sort of a mess right now and I want to totally redo it with liquid cooling and a TJ07.
