erwinz You are great if u unlock dfi to 1333 strap
"So if you have a 1066fsb CPU there will be some headroom in the 1066fsb mode but the chipset will eventually give in and overclocking will be hard
We are seeing this with the boards that are stuck on the 1066 strap like the DFI etc"
http://www.xtremesystems.org/forums/...d.php?t=105703
"Now, it looks like Asus have found a way to engage the 1333 strap on the CPU but are tricking the NB into thinking its on the 1066 strap. It also looks like they have the strap auto switching in bios with the end user not seeing they have moved to the 1333 strap on the CPU, while this is a slick way of overclocking it also will confuse some."
and indeed ASUS DH gets to FSB 450 and above
"CPU Clock Setting 440"
I just can't go to 415, and a left yhe memory loose latency and 4:3
Must be that I have E 6600
The only explanation is that 1066 strap sets a MAXIMUM BANDWIDTH TO 8400 MB/sec
and that with much NB cooling
if i take down fan rpm toward NB it SYS. STALLS
MUST BE
407 x 9 = 440 x 8(your proc multipler) = 3700 MHz => results the same mem bandwidth
What is your memory bandwidth (with sandra) Erwinz ?
Originally Posted by erwinz
