The 7950GX2 works without issue for me on the DS3.
Shawn
Shawn
Any one has problem using the first PCI slot (close to PCI-E)?
I tried a Blitz PCI wireless network adapter on 2 DS3 mobo, never works. The system does not boot with wireless card on first PCI slot.
which cpu voltage is true?
BIOS? EasyTune Advance mode? EasyTune PC health Hardware monitor? CPU-Z? lol
I need some help getting a hard drive recognized. I have a 80gb sata which is fine. On IDE I have a Sony dvd drive and a 200gb hard drive. The hard drive isnt being recognized. When it's set to master and the dvd is set to slave, the dvd drive doesnt work and Windows acts weird and freezes up. Then when the dvd is set to master and the hard drive is set to slave the dvd is fine but the hard drive isn't recognized. Anybody have any suggestions?
the SB after is so hot, but i place 1 fan 40mm and stay cool now :P
My Audigy 2 won't work in that slot.Quote:
Originally Posted by harbin
Originally Posted by codylawyer
first of all how do you have the dvd and the hard drive on the cable.
in order to have the hard drive as master it must be on the END of the cable. and the dvd on the SECOND connector.
second,,, how do you have the bios set ?
set SATA Native mode to Disable
Set SATA Controller to IDE unless your using raid.
i hope your loading windows off the SATA drive...
if that still doesnt work set the dvd and hard drive as cable select.
some configurations dont like master and slave but prefer Cable select.
but some dont like cable Select and prefer Master and Slave.
you just have to swap them around to find out.
i never recommend someone put a IDE drive ont he same cable as a DVD-Rom unless they have no other choice. which unfortunately is the boat we are in with the DS3.
you may want to opt to purchase a sata hard drive to replace the IDE one.
i mean for heavens sake you can get 350gig drives on Newegg that use the new Parallel Writing for 99 bucks.
and stick the ide drive in a usb enclosure.
Thanks for response. I didn't know it matter where on the cable the hard drive was. The hard drive was on the second when everything was acting funny. I will try the cable-select setting in a bit.
Is the Gigabyte DS3 bootable? Can you get into DOS with the CD?
Is that to me? If it is, I can boot and I have windows installed on a 80gb sata drive, and its just my 200gb ide storage drive that isn't being recognized.Quote:
Originally Posted by Delphi00
I tried plugging my X-Fi into the lowest PCI adapter and it didnt work either. I had to move it to the one right next to PCI-eQuote:
any one here uses the digital optical cable to connect speakers?
I have a 5.1 speaker, and only 2 front speakers work when I use digital optical cable, anybody know why?
The only time it matters which connector you use is if you set your drives to cable select (CS). If the drives are specifically configured as master/slave then you can use whichever connector you prefer.Quote:
Nope, see the Bios thread, GAR got it worked out.Quote:
EDIT: Does anyone know where the System temp diode is located on the board?
Same problem here. Using a SATA drive to boot, IDE burner ok, but my 250gb WD IDE drive is labeled "unreadable". It's a known working drive, so it's the DS3 being weird again. Also, only with native sata enabled can I OC.Quote:
Could you advise me activ cooler fot northbridge for ds3?
this stock pasiv is very hot
fsb 400 - about 48-53*C
fsb 266 - about 40-43*C
@CrazyJohn: Try to replace your DS3. It's definetaly holding you back. I just got another DS3 and now I'm up to 3.35G. And my Goodram works flawlesly with CAS3 or CAS4. With my previous DS3 I couldn't OC more than 410FSB and I could use CAS4 only for benchies, with CAS3 didn't even boot.
Originally Posted by dan007
I use TT Extreme Spirit II and it's great! Idle is around 27C and load is max. 35C with fan around 2500RPM. Max RPM is ~5000RPM. It's also very silent.
dan:
I just slapped on a Forcetake Jing Ting. The NB no longer hurls fireballs at me.
Just flashed to F4 and temps spiked on idle like 6C. CPU-Z was showing 1.4 instead of 1.3. I also found it would happen with the RAM too. It spiked to 2.1 and there's no way of setting 1.8 AFAIK, so it's at 1.9. The only one I didn't move was the PCIe, but now I'm wondering if that's getting overvolted too!?!? Anyway to check that guys?
@Jodiuh:
def mem V @ F4 bios is 2.1V !!!!
Hey, i tried to plug in a extra ide hd i have and it didn't work. How would i get it so the computer sees it?
I'm using stock everything and I tried OCing my E6400 from 266MHz to 300MHz but it froze during the windows loading screen. Also, EasyTuner freezes my computer when I try to overclock anything, is something wrong here? Do I need to use different voltages?
Are you sure? I don't think that's right, because I still have my vdimm set to +0.3v and I'm running stable. Easy Tune even shows my vdimm @ 2.1v in windows.Quote:
Originally Posted by CrazyJohn
Normal is 2.1v +.1 goes back to 1.9v so +.3 is 2.1v again.Quote:
Originally Posted by Ruhnie
Ok that's just weird. So I wonder how many people with 1.8-1.9v RAM are frying with the F4?Quote:
Originally Posted by BottomsUp
