Using a multimeter, voltage is 1.38v@1411 when AB reports 1.31v only.
Impressive Cowie :up:
cowie really good revision card, nice clock :up:
My 3x GTX680 SOC@ STOCK 1306/7000
http://i.imgur.com/8CCaAIK.jpg
Just get some cooling and find a way to get 1.42-1.45v your card will game 1450+ np
Thanks you guys
Got the card prepped for dice i think i might do some bf3 @1600... i want to run down my pb fsx with the card too.
http://www.3dmark.com/fs/15744
@sergio
Nice going there how does it run in firstrikeX? never got to test my tri 680 rig in that bench.
same settings as above new 3DM
http://i.imgur.com/ClVKOPq.jpg
the first bench seem low for what ive seen and i dont know why
Man thats what my titan sli do in fs around 20.5k gpu score your tri 680 at 22k,thats pretty good.
tit sli
http://www.3dmark.com/fs/238146
Sli 680 fs
http://www.3dmark.com/fs/80102
BTW
what you think today spain? or brazil? :D
Thanks cowie !!!
man im mad we lost with brazil ONLY cauz they where lucky now Italy the same we got a goal nulled and a penalty nulled cauz of the damn referee...jesus
i dont like none of them really, i think Brasil will win but Spain is hard to beat also
URUGUAY !!!!
I tried 2 methods to give a little more juice on the 680L, artmoney and Rbby258 MORE voltz.exe, and the 2 work great.
Rbby258 MORE voltz.exe is more simple and give same results. It seems this tool works with cards equipped with CHL8318 voltage controller chip only.
On my card, with a multimeter, value 100 on GPU voltage gives 1.38v, 120 1.4v, 140 1.43v ...
I will wait my waterblock to really test but this little tool works great.
If you want to give a little more on your cards andres, seems they're are compatible. Worth a try. :D
all infos found here : http://www.overclock.net/t/1398725/u...ng-tweak/0_100
This is my first OC attempt:
https://lh5.googleusercontent.com/-p...-GTZ680SLI.jpg
As you can see I am just using the simple GPU Tweak atm.
I've got pretty good cooling on these cards (50C at the end of a burn-in test). Can I leave the voltage turned up since my temps are low?
Thanks!
nice white pcb :up:
shame that all these are not :yepp:
I was holding out for the white KFA2 to go on offer, but I couldnt resist this MSI Power Edition offer for ?260:
http://www.overclockers.co.uk/showpr...odid=GX-213-MS
Going to SLI it with my reference version ofc, which already does 1250 / 7200 clocks, so I'm more hoping that the power edition will at least match that, and I'll have SLI GTX 770 performance.
Which is stupid because I dont have any games that wont run maxed out on my aged CPU and reference GTX 680 at stock speeds, but may as well grab that MSI Power Edtion while its on offer, and if I dont want two then sell my reference edition.
___________
Ok, I figured out that these power edition GTX 680s are just rebadged, lower clocked Lightning editions, and can be flashed to full lightning editions. They were put back on offer for ?280 this week only, with yesterdays ?260 offer being one per customer only, so I may as well grab a second too while they are still around at that price, and sell my reference 680 and old 560 tis that I still had lying around as backup cards (no need to keep back up cards with SLI coming).
GTX 780 / Titan are way too expensive compared to SLI 680 performance, and I should be able to get ?400 back from selling all my old cards.
And yay!
http://i.imgur.com/jSALYzA.jpg :D
Results -
I7 980 @ 4380 Mhz
Ram @ 1905 Mhz 7-9-7-24
GTX 680s @ 1202 Mhz GPU / 7600 Mhz Vram:
http://i.imgur.com/aqeqMCd.png
One of my cards will only max out at 1202 Mhz, the other at 1267. I'm going to send the first back for a replacement under the 14 day satisfaction guarantee, its crap for the cards build quality. I wouldnt expect any less than 1250 from these lightning PCB / Military class III cards.
I unleashed this beast a bit more i can now bench at more clocks :)
this is a start 1348 Core / +500 mem
http://i.imgur.com/n1AwdEZ.png
and can game at those, see furmark runing at the back
1378core / +500mem
http://i.imgur.com/0Ra1Kp6.png
Cheers to all !!!
Sergio
With a bit more tweaking, I got up to 13k in firestrike:
http://i.imgur.com/0qj82qV.png
