anybody tried this yet?
http://forum.abit-usa.com/showthread.php?t=136884
Hello, i did a small oc to 3.6ghz, stock voltage. RealTemp shows 30, 35 degrees idle, core temp and occt 40, 45 idle. Which do you think is accurate, or at least close the to the real temperature. Ambient is about 20~22. Temp in load after 1 hour of occt is 50, 52 by core temp, and 40,45 by realtemp. Also i'm getting a beep from pc speaker, nothing happens, the beep is very random very annoying. Thanks.
just ordered all my parts from newegg couple of hours ago, can't wait to pair the abit w/ the q6600, hopefully the q6600 is G0 stepping snice it's been out for awhile now. the parts i ordered are down in the sig box
well from reading lv coyote it seems most Q chips have temp reading issues with B16. You would think after months it seems they have been working on this bios 16, they something this blunt wouldnt be an issue..hope they put a new one out quick. Im still sittin on 16 because everything seems fine, besides temp inaccuracy.
and good to know that 45nm only does half multi's..wasn't aware of that. Then again I havent been paying much attention to new chips lately.
IP35 PRO inside Stacker 830 SE...inverted ATX..benching now...see you in 8-10 hrs or so
http://img514.imageshack.us/img514/7...utesdl6.th.jpg
http://img339.imageshack.us/img339/6...0095as5.th.jpg
32 minutes:
http://img132.imageshack.us/img132/9...nutesq7.th.jpg
don't see to many BTX runners! nice set up
8 hrs on inverted ATX.....
http://img397.imageshack.us/img397/5...8hrsjl9.th.jpg
Now, I'll try regular ATX, or as someone says, "right side up."
http://img355.imageshack.us/img355/8...0097hp3.th.jpg
http://img139.imageshack.us/img139/3...utesoq0.th.jpg
see you in 8-10 hrs....
Cpl Ledanek- I think you have the same batch that I do (Q748). They are among the most difficult to OC from what I've read. I'm stable at 3.8GHz@1.35v, but cant get anywhere near 4GHz at stable. BUT, I'm not willing to go higher than 1.37v to try since I plan to keep this long term.
any links to this? I don't even plan to stay in the 3.6Ghz since there is no need at this time.
thanks for the heads up :up:
2hrs
http://img241.imageshack.us/img241/2...2hrsqf9.th.jpg
http://www.overclock.net/intel-cpus/...ml#post3299649
There were some others, but I can't find them...
not all 45nm processors have half multi's.
my Q chip has temp differential of 9C between each dual core set...my original QX9650 had a stuck DTS sensor which prevented me from getting an idle temp reading...once i pushed it with P95, it would respond but the overclock (and Vcore) had to be high enough to produce the heat.
Quick ?, jsut realized there were two revisions of the pro. 1.0 and 1.1.
WHats the difference between the two, anyone better then the other.
Looks to be a great cheap board. Anyone run into issues with Crossfire HD3870s on this board?
DISCLAIMER: I'm a n00b who looked, asked around, and collected answers on the question of: Is there a temp change when the Abit IP35 PRO is placed CPU DOWN/ATX or CPU UP/reversed ATX?
Now collecting all my post, see if there is a difference in temperature, at least, maybe forgoing performance issues at this time.
32 minutes into it:
__________________________________________________ ___
2hrs...
Finally 14 hrs on ATX
http://img246.imageshack.us/img246/4...4hrssa6.th.jpg
So, is there a temp change?
But... which is the best bios (beta or not) for a q6600 g0???
It would be nice..., but it always defaults to 1.8 volts, even if your memory want's more. Most, but not all memory will allow you to boot into bios at 1.8 v, and then you can change the voltage.
For me, the automatic timings would work (not great, but work) with 2 sticks, but would fail totally with 4 sticks - giving me a meaningless error message about a corrupt file or something.
People on this forum aren't generally using the 1.8v memory at stock timings, and the "automatic" settings were likely focused on helping people with stock setups.
My system is much more stable with manually set timings.:)
Preaching to the choir as we presumably already all have one, but perhaps for our buddies (today only): http://forums.slickdeals.net/showthread.php?t=790951
Looks like Abit is dumping excess stock of IP35 Pro's to make room for the IP35 Pro XE's: ABIT IP35 Pro $100 + Free Shipping after $70 rebate @ NewEgg *TODAY ONLY* (use coupon code: mb48FS)
Should I get one now @ $100 shipped or wait for the XE's to roll out and possibly get it cheaper :shrug:
What I'd really like to know is if the Pro's will be able to handle 1600fsb in which case it would be pointless to buy an XE?
my friend has basically same setup as me and im helping him overclock but his pwm is hitting 80c lol and his pc is shutting off we turned off the temp shut off just to see if it shut off and still does so is his pwm making his pc shut off every other temp is perfect except pwm...
any advice?
Did you perform the bolt mod on the board, as well as replace that peice of plastic they call thermal interface material and replace it with some ceramic based (white) paste?
