Tried it, and it didnt do the trick. Gets me in to the desktop, but the its BSOD or freeze and reboot.
Upped the mem volt one notch but same happend again.....
Look at the areas in BOLD i edited for you. Give them a try and let us know if you get any further or actually stable.
Look mainly into RAM, 4x1g or 2x 2g is a load on the NB, Also, limit use of performance boosters in beginning. Light or disable is best for stability.
Just try to keep NB cool and you should be fine, about just under 50c under (46c idle) loading is OK, less is better.
Good luck.
Just got my new q6700
pop'd it in and when it boots I get the cpu init on the lcd poster, and the computer then cycles booting,
powers up for a few seconds and then shuts off, then powers up then off, over and over.
doubled checked the install, its 100%
Am I missing something or is the chip dead?
Never mind
Seems in my haste, it was operator error :shakes:
This happend to me when I removed a Q9450 to replace w/ 64nm E6750. I was on BETA BIOS v1004. Not sure what really solved it, but my BIOS just became buggy ever since the switch, yet whan on the Q9450 for over 2 months it was fine other then the limit of OC ability (CPU limit, not mobo).
I disconnected evrything except GPU, CPU, and 1 stick of RAM cause I was also now getting the DET_RAM bug and occassional CPU_Int message. It took several clear of CMOS and I even reflashed BIOS and it finally got half way back to normal, NO more CPU_Int but I randomly get the DET_RAM on cold wake up from S4 (S3 never works) but waiting a few seconds seems to warm it up so a reset kicks right back in to as normal and resumes just fine. This used to happened once in a blue moon on my BETA v0903 outfit.
I also had to do some basic manual OC profile settings to get her to boot stable and then fine tune. use the F1 to enter set up and make basic settings , save to profile and continue. at least you can keep going back on lock ups.
Not sure it's the same but hope it helps.
I was really bumed at first, but I pop'd it out and back in and the bugger booted right up.
Cant get 3.8GHz, to bad my VID is a crappy 1.325.
I can however get a nice 450x8@1200ram ( priming now) with decent volts 1.50v actual and full load 58c, so I am happy with that.
I was hoping that the 10 multi would give me a 4.0GHz quad core 24/7 setting but I guess its not to be.
Seems I will have to sell a kidney and grab a QX for me to achive my goal. I am torn between a C2D or a Quad for my daily use, I love the bandwidth the wolfdale gives me, but I miss the raw power of a quad. Maybe I should go AMD:rofl:
In regards to your S3/S4 issue I have for the first time had S3 fail, OCCT was running and it would not recover from S3, black screen only, I had to reset to get the rig back, first time its ever happend, I will do some testing this weekend regarding S3/S4 and see what I can come up with for my settings and share my results.
I threw my Q6700 back in my rig tonight and I'm testing it out at 9x425 to see if it can handle it with decent volts and temps. If all goes well, my QX9650 might be for sale. (Not selling because I want to, selling because the CRA just sent me a bill for a large sum of money :mad: because they overpaid me on my tax return two years ago)
So far it's the Q6700 is going strong at 1.448 small fft at 3.825
currently i'm in the market for a new CF capable board as my iX38 has some boot issues with 2 cards (every 3rd-4th boot the cards don'T init, fans stay at 100%, no image) but p45 seems to be a bit disappointing (see performance comparison p45/x48 crossfirt).
are there any real benefits of flashing the X48 bios and what is the difference between the maximus and the P5E???, what is the max FSB for 45nm dualcores and vdroop with these cpus???
BTW i use an E8400 which is kinda limited by my aircooling right now and i had no time to test it with my watercooling before disassembling it :shrug:
another question: how hot does this thing get ???
guys i cant sit here and read thru 230+ pages.
are we still on 1201 bios ?
i am happy where i am so i dont really need to update the bios but just curous since an update hasnt come out in a while.
Hey guys!
So I just updated my motherboard BIOS from ver.907 to ver.1201
And now the overclock settings I've been using won't work anymore, my comp just keep crashing :(
These we're the settings;
Which settings I should go with to hit at the very least 3.6ghz :sQuote:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : AUTO
- Ratio CMOS Setting : 9
FSB Frequency : 423
PCI-E Frequency: 100
DRAM Frequency: DDR2- 846
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 50
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Ai Clock Twister : Strong
Transaction Booster : Disabled
Relax level: 0
CPU Voltage : 1.38175
CPU PLL Voltage : AUTO
North Bridge Voltage : 1.49
DRAM Voltage : 2.20
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
E8400 SLAPL FPO/BATCH # Q748A144
1201 only lasted on my computer for about 4 or 5 day. Then I have a corrupt CMOS, and had to restore from the retail cd. Back to 0907
Hi I'm new to communicating on forums, so please feel free to inform me if I'm violating forum etiquitte.
I've been trying to get my system stable for some time now, and, while Windows boots fine, I get frequent BSOD's, mostly when resuming from sleep, but not limited to that. I have run the minidumps through windbg, and the BSOD's seem to be coming from myriad, unrelated sources. I have feared for a while that I am just really good at frying RAM with this board.
Therefore, since I just got my mushkin ram back from an RMA and I don't want to fry it again, I was wondering if someone could evaluate all of the BIOS options available to a maximus formula owner (401, 907, 1201, rampage conversion) because I have gotten mixed messages and want to pick the most stable bios out there.
I think centralizing this information could help a lot of people. thanks.
Arlak do you run Loadline calibration on or off ? if on up the vcore a bit and turn it off... this is the biggest source of all BSOD on these boards... secondly for ya ram be carefull as the board overvolts the ram dimms so for 2.0 volts plz set 1.92 or such...
Curcial says that Dram Static Read Control should be disabled, the ram dosent like it.
I dont think this chip is going to stay. Its not bad but I'm not overly happy with it, I also just flashed back to a Maximus bios and I can say 1201 is a dog of a bios, WOW is it slow compared to RF 403. Going to flash back to a Rampage bios and retest the chip. I did however only require 1.48 volts for 450x8 on the Maximus bios tho compared to a 1.50 for the same clocks on the Rampage.
http://i237.photobucket.com/albums/f...inger/6700.png
BIOS 1201
Extreme Tweaker
- Ratio CMOS Setting : 8
FSB Frequency : 450
PCI-E Frequency: 110
DRAM Frequency: DDR2- 1080
CAS# Latency : 5
RAS# Precharge : 5
Row Refresh Cycle Time : 35
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Enabled
Relax level: 0
CPU Voltage : 1.49
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.53
DRAM Voltage : 2.12
DDR2 Channel A REF Voltage : DDR2-REFF
DDR2 Channel B REF Voltage : DDR2-REFF
1201 beta is garbage for me, this is only in beta form correct? I went back to 1102 and all is well, all mobo settings are stock, manually set lowest volts for everything and it takes my e3110 to 4.1 prime stable for 8 hours, my p35 wouldnt do it at 1.35 at 4050mhz.
I guess I willl fiddle some more, I got a hair across my ass to buy 2x4850's and I wanted a true X-fire mobo, i nailed this puppy for $140 shipped open box from mwave, it arrived with EVERYTHING, look brand new, static bag sealed and all.
