3d Mark 06 problem caused cos of the PSU
Ok guys so about my score in 3D mark 06 problem I did so research and after testing i realised that my GPU need a PSU that is above 550 Watts and 12v of 40 Amps which mine is 10A http://www.ebuyer.com/product/135196 so even though tmy PSU is 800 Watts it would be sufficient but not powerfull enought to run on my new CPU that am now using Q9650 Oced to 4.3 so (before I had my famous Q6700 oced to 3.9) so basicly I now need a new PSU that is capleble fo providing 40 Amps for both 12v rails... Is gonna be really expensive to buy one for all the set up I used so Which PSU Do You Guys Recommend??
I can back this up as I used my GPU and others on differents boards and cpus but unfortunally I don't have a PSU thats good enough :shakes: .....
Cougar 1000 CM? good enough? i think so
Ok guys so i followed your honest opinion as always and i decided to go for the 1000 watts Cougar 1000CM PSU which has 24A on the 4 12v rails so that should be enough to keep my GPU stable and the CPU too... :Dhttp://www.compucase-hec.co.uk/psu_cougar_cm_1000.htm
