Wow, awesome!!!
Try the Sigma 50 1.4, heard from some that the optics is comparable to the L.
Oh dang, sorry I just spotted this one. Thanks for the info
So in a nutshell RAW makes it easier to post-process your photos? Do you need any type of specific softwares for converting RAW and to process them? Also, how much larger are RAW files compared to regular JPEG files?
I would never shoot anything other than RAW, regardless...
What do you guys think about the sharpness on this image? I feel it is a bit softer than I would like, especially after Flickr processed it. (Its a meaningless shot I took to mess around)
http://farm6.static.flickr.com/5134/...e3ace4b3_b.jpg
Celebratory Masturbation Injury... sounds interesting
http://farm6.static.flickr.com/5293/...48fb611d_b.jpg
Over Grown by Ilya Cherkasov, on Flickr
I don't have a 'pro' account on Flickr, so I can't post originals.
@Ikiller123 RAW shots are about twice as big as compressed shots on my D5000 they average 10MB. You might be able to shot RAW + jpeg and additionally create a small jpeg in camera too. I use Adobe Lightroom which is a superb programme for cataloging and processing RAW images. Nikon has it's own proprietary software capture and capture NX2 which is a good start but not a patch on Lightroom.
Most of my RAW's are about 15MB, which isn't a issue even with a tiny 4GB card. A few hundred shots is fine with me... I don't see any need to ever use RAW+JPG, since the JPG just clutter up the card, and waste space. Why shoot anything less than the best? They're not any harder to deal with if you ask me. If you're running windows, it can be hard to quickly preview them, thats about it. If you demand a card that can handle thousands of shots, high capacity cards are cheap these days... High speed high capacity, those can be expensive. I would always run any JPG into CS5 before posting it regardless, just for level adjustment, lens correction, and sharpness tweaks. Most of my pics are edited in under 10 seconds, and then straight to Flickr.
Bigger, but it depends what you are using. 12 mpix is around 15 mb. You need something to process raws, either free or payed software. Most used is probably Adobe LightRoom and Adobe Photoshop (Camera RAW). But theres quite a lot of SW to use. And usually, when you buy camera, you get some SW free with that to develope RAWs. Though, probably only Canon/Nikon/Olympus has decent SW (maybe Sony now too). No idea about Pentax, never saw. Panasonic uses SilkyPix, which is pretty crapy, at least those supplied with Gx line are.
Unfortunately to get best result, you need to test a bit of SW to find whats best for you and your camera. While Adobe is good in being able to convert pretty much everything, its not always best choice from color/sharpness/noise point of view.
Kain, I'm really impressed with your photos! You have a very unique look to each one like a signature.
Any sharing of p.p. on how to get the look, or is it some kind of warming filter?
Thanks! It's mostly just playing with curves and color overlays to get the tones I want, other than that it's just the picture itself. No filters used.
nice shot weevil...
is that a strobe lighting the rim of the cave/arch ?
Thanks, no I changed the color from an over exposed bright white that was shinning through there, (sun was right on the other side). I was attempting to mellow it out so the blue ocean would show, and in the process added black to the white, as I slid the slider over I just wanted to see what it would do, and liked how it looked black. I couldn't get the blue to show..
Yep great shot Weevil Is that place near you , definitely worth taking a few 100 shots and experimenting. I reckon you could sell that print.
It's very close, we're there all the time, hardly anyone goes there because you have to hike down a cliff to get to it.
Hmm, where is that, Weevil?
Thats at Panther Beach, its about 9 miles north of Santa Cruz, Ive accurately pinned it on the map in flickr. Lemmie know if you want a google earth link.
Edit: here's a google link. http://cid-9ffb6e23a9857b7a.office.l...r%20Bridge.kmz
Interesting! I will go down there one of these days
