Originally posted by SKATAN
can I see a sandra2004 screen just like mine ? ;) with all the numbers
If you want to compare scores, you come and get the Sandra2002 software. Or, forget it. ;) That's the version I always run. ;)
oh and increasing fsb (i need 2 mhz to get the same score as you:D) , sandra benching then lowering fsb opening cpu-z doesn´t count ;)
You are saying to me that I cheat. Accusing me of cheating when I didn't cheat would make me mad would it.
Since you tell me I cheat, maybe it is you who cheat. Wpcredit tweaks is cheat too. You do those tweaks, I don't even do wpcredit tweaks and you tell me I cheat? That's even worse. ;)
Don't even bring anything about cheating. I'm not a low class people who cheat and b.s. around. (read again, to clarify)
i only changed 2 offsets that change two timings , some that are on the dfi bios
Wpcredit is cheat.
All I have done was to set the timing to 8-2-2-2-2.0-13-15 FastCPU decode, 128bit DC, CPC On. No Wpcredit, No Clock gen, nor any other programs to alter the system's setting. That's it.
You have earned 1 cheat for telling me I cheat.
You have additional cheat, total of two, because you been using Wpcredit tweaks.
2 cheats vs. no cheat. Who's the cheater here?
wrong....Quote:
if you can do that score lots of guys can do it because you dont need wpcredit for it , just bios ill test it tomorow at a friends with the same dfi bios
Have you thought there are also the score difference between the brand, type of RAM modules? Maybe my score is a little higher than you due to my ram?? Think about it.
if you expect everybody to score the same, the 3Dmark should be exactly the same with same board, same fsb, same clock, same timing, same bios, etc, but are the 3Dmark scores the same? piFast v4.1 the same? Other cpu calculations like the Calcum.10 the same? Whether they are synthetic or real-world apps/benches, the scores cannot be the same. I'm not only talking about fluctuations but the scores can be better or worse depending on the hardware you have. Every single components makes the difference. That is more idiotic comment I've heard from you. Shame on yourself. :rolleyes:
Something you need to realize is that it's not right for someone to "dictate" that "we" all must get SAME score because my overclock is the same as yours. This is un-acceptable. Maybe this will teach you something.
In the very first of my post you quoted, I didn't quote you and replied to you to piss you off. That wasn't my intention. Obviously you took it badly.
If you didn't accuse me of cheating, I wouldn't have said Wpcredit tweaks is cheating. I don't consider Wpcredit cheating, but it is now cheating since you say I cheat. Do you see what I'm getting at?
