that can't be the complete logfile .. is it? post fahlog-prev as well if you got it. If you don't have the prev log, and this is all you got, you made a mistake with the install, as I said, did you read the guides? Sli disabled, clients in the right place? You got two cards, you should have two clients running and thus post two logs ( each client in a seperate folder ).
If you didn't do all that, delete your current client and disable sli, then run
www.mtm78.nl/maxfah/publish.htm, install the gpu clients and just enter your name ( team number should already be 36362 ), don't mess with the other options and after install go to c:\maxfah\clients there will be a folder for each instance and you can run them from there ( if you want to create shortcuts be sure to change the start folder for each shortcut ).
