Strange cpu's these when it comes to temperatures.
I was running 2.5Ghz & 1.475v and the cpu was 48°C idle and about 58°C load.
Right now I'm running 2.6Ghz & 1.45v and the cpu runs 41-42°C idle and a 49-50°C load.
I don't get it...
I don't get it...
ha, What are you using to measure Temps? BIOS?
Speedfan 4.22
Yeah, which VX did you buy?Quote:
Originally Posted by S0nic
Hello everyOne !
I got my Athlon64 3500+ 0.09µ Winchester, today, I haven't open the box yet ! because I'm not sure if I got a good CPU stepping, so I looked through the Box at the CPU core, I can see the number of the CPU stepping
ADA3500DIK4BI
CBBID- 0501-EPMW
1126385A50059
Can someOne, to confirm me, that I have a good CPU model ? :confused:
I' already have a 3500+ 0.13µ Newcastle
ADA3500DEP4AW
CBAXC 0436WPMW
but I wanted to try out the winchester, because alot of people told me that the Winchester is better than the Newcastle you can hit with the high fréquency more easier and there's less heat. I like to make sure I got the good CPU stepping, befort I take it out of his Box and test it :slobber:
Not to be rude, but... this thread is about the only 3500+ that's neither a Winchester nor a Newcastle which are the ones you have. You might be better off searching for a more appropriate thread to post your results on. :stick:Quote:
Originally Posted by AMDfan
No, the Clawhammer Athlon64 3500+ is better than any CBBID Winchester.Quote:
I don't necessarily agree with that. My Clawhammer only does 2600, while I know that there are some Winchester 3500+'s that do exactly the same on air but don't get as hot! So I'd say if you get lucky and get a good Clawhammer you can surpass a good Winchester. But if you get a bad Clawhammer you'd do above average for a Winchester but you'd be running hotter and probably using more energy to run it at that speed.Quote:
Originally Posted by sauria
PC4000 Gold VXQuote:
Consider yourself warned, AMDfan.
Make that 2.5ghz on stock volts. :) Nice chip I've got here.
With the 80mm fan Smartguardian says i'm around 38-39C idle and i'm topping out around 60-61C in Prime95. Its reporting around 1.58V vCore.Quote:
Originally Posted by Chivalry
I've got a new 92mm Vantec Tornado but i dont really want to install the thing cause i hate the noise level even on my Aerogate II. Hopefully my 92mm Panaflo will come tommorrow.
Can any of you with the DFI Ultra-D board give me any tips for overclocking this chip?
I managed to get to 2.5GHz at 1.43 V recently after some burn-in. :cool:Quote:
Originally Posted by GregP24
Well, I felt daring and decided to remove the ihs and apply some as5. I'm at 2808 (312x9) with the voltage at 1.55 and temps of 39c idle and 50c under load. btw, I'm using a xp90 with a panaflo fan. Before I removed the ihs my max speed was just over 2.7 and max temps of 55c. I'll post a pic as soon as I get done with super pi 32m. I've done 1m through 32m back to back to test stabilty.
Interesting... I wonder if your results are isolated or typical of these CPUs. Looks like you got a great CPU though if you can do 2800 at 1.55V on air!Quote:
Originally Posted by motoolfan
ya, what's the stepping?Quote:
Originally Posted by Ackbar
That sounds like one of the best chips here so far then... I could do 2.7ghz at 1.5v but anything above that required a jump in vcore over 1.6v... the chip maxed out at 2980mhz....Quote:
Sold it yesterday to some lucky fellow at a massive discount ;)
The stepping is 0505 DPMW. A few days ago I did the power supply sense mod on my 3.3v and 5v rails and that helped the computer in stabilty
http://img17.exs.cx/img17/7501/286bm.th.jpg
Thanks, I got the PC3200 Gold VX KitQuote:
That's interesting about the removal of the IHS. I'd try it myself, but I'm not that daring.Quote:
Hmmm. Anyone else wanan try taking off the IHS and see what happens?
It's killing me not being able to run my machine. Still need Ram, PSU and HD...grrr PArt Time job paychecks BLOW
hi guys,
it is by passing super pi 32m system is consider stable for ram & cpu
This stuff sure NEEDS the VDIMM to run tight timings.Quote:
CAA2C
Looks like mine wont run stable more than 2.6Ghz no matter what vcore I put on to it. Though I could run 2.6Ghz at stock vcore.
if you cant go up go down :P, how low will it run at 2.6 w/?
