Since it can't be found here in Spain (only pre-orders) I just ordered it from www.bytesatwork.be last night. Hope they come with good news on monday
oh man, my friend wants me to make him a computer, i could so easily sell him me 754 and get a ultra nf4, luckily he has to save money so AMR and E0 cores can come out, but i really want some new toys!
I did heard that the VX doesn't have the divider problem
with the MSI Neo4 MOBO.
But can anybody tell me if there is a divider problem with the VX and the
DFI NF4?
I just want to make sure there are not any problems. ;)
:confused: What d'Ya mean with divider problem? Using .5 multis on A64?Quote:
Originally Posted by formyfaith
This is caused by memory controller and not by RAM......... :stick:
:toast:
i get always errors, when i run MEMTEST.
the gskill 2x512 LA runs with:
200mhz at 2-2-2-5 1T --> errors
300mhz at 2,5-4-4-8 2T --> errors
i also tested with prime with 200mhz at 2-2-2-5 1T
it runs perfect over 2 hours, but the i wanted to stop that test --> *boom* bluescreen.
wtf could that be?
the board?
the ram?
or me?
:rolleyes:
:D Did Ya try with 2.9 Vdimm? Mine are running stable with that voltage.Quote:
Originally Posted by Patrickclouds
BTW MEMTEST sucks - after trying several hours to get a stable setting without errors the rig didn't even boot with it........... :cord:
i tried with max 2,8 (bios option)--> 2,85real
ok i will try it with 2,9 that should be 2,93 real
but i was a bit confused, that i get errors with 200mhz at 2-2-2-5
edit:
no, with 2,9vdimm i also got errors :eek:
:confused: What revision of MEMTEST do You use? Try the latest....Quote:
:toast:
i´m using memtest 3.2
this should be the newest version
i´ll test the gskill in my shuttle (sn45g)
and an old corsair module on the dfi board
:D Here're two pics:Quote:
Originally Posted by cantankerous
http://de.geocities.com/hardcoreclocker/A64Sys005.jpg
http://de.geocities.com/hardcoreclocker/A64Sys004.jpg
No problem at all - taken on NEO2 but DFI NF4 has almost the same RAM slot position.... :toast:
Have you tried one stick at a time? Could be that you have a faulty stick?Quote:
No problems here.Quote:
OPP
Originally Posted by OPPAINTER
So glad to hear that~! :)
I love my VX ;)
so thats on the dfi right?Quote:
i saw the same thing on the msi k8n neo2 :mad: but after some bios changes i fixed it but then it wouldnt be stable above 220fsb even with 3.9v running trough mem :stick:
Where can i download the latest Bios for the SLI-D
I got the board and the stock Bios is 119 , someone can help me please ?
DFI taiwan site has them.
any word on how 2x512mb BH-5 Clocks?
id like to see 2x512 BH-5 at 3.3 and at 3.6 if someone could...
i´ve tried only one stick
the first stick passes memtest 3 times without errors
the second stick passes memtest 3 times without errors
then i tried both together in dual channel and i got errors.
so i decided to try both sticks in single channel
and voila they pass memtest 2 times without errors
now i´ll try both sticks in my shuttle in dual channel mode, if they pass , it must be the dfi board that makes the problems in dual channel mode :stick:
here you can download the beta bios ;)
which BIOS is it Patrick?! maybe it's BIOS update time! :D :D (IIRC, bigtoe did talk about improvements with RAM...)
i flashed to the newest bios 126
After reading all of this I have only one thing to say...
Thank God I didn't have the money to buy the A8N and will be able to go with the DFI!
Guys remember to flash to 126 straight away with your boards, it helps clocking a great deal.
omg, i want this board. :mad: when is zzf/newegg going to get it :(
The bios got Memtest86 build in and cpu test build inQuote:
Originally Posted by bigtoe
:toast:
Hunh? You mean its a seperate program attached to the bios file. Right? I guess I don't understand.Quote:
Originally Posted by tictac
